> 914 gearbox metal mixture
MikaM
post Aug 11 2016, 10:42 AM
Region Association: Europe
I need information how to weld gearbox 914/-70, mixture or welding instructions (IMG:style_emoticons/default/smile.gif) Mine has some cranks near the starter motor..
Thank you (IMG:style_emoticons/default/smile.gif)
-Mika
oldie914
post Aug 14 2016, 02:13 AM
I also have a case you can have. Shipping from Germany to Finnland would cost about Euro 30. If you are interested, I will send pictures.
Keep in mind you will need to readjust the R&P if you change the case. Need to set pinion depth, differential bearing preload and backlash.
MikaM
post Aug 14 2016, 03:14 AM
QUOTE(oldie914 @ Aug 14 2016, 11:13 AM) *
What R&P mean? I sent you PM (IMG:style_emoticons/default/smile.gif)
MikaM   914 gearbox metal mixture   Aug 11 2016, 10:42 AM
bretth   Welding Aluminum is not easy. I have seen pros scr...   Aug 11 2016, 12:10 PM
Dave_Darling   Isn't the transmission case a magnesium-alumin...   Aug 11 2016, 12:17 PM
bretth   Isn't the transmission case a magnesium-alumi...   Aug 12 2016, 08:27 AM
Beebo Kanelle   http://www.locknstitch.com   Aug 11 2016, 12:50 PM
Mark Henry   Mag is hard to weld and it warps, you can do it wi...   Aug 11 2016, 01:10 PM
MikaM   Thanks :) I'll try to get it welded in some sp...   Aug 12 2016, 04:18 AM
Krieger   What would it cost you to replace the entire trann...   Aug 12 2016, 09:02 AM
stugray   What would it cost you to replace the entire tran...   Aug 12 2016, 11:31 AM
MikaM   What would it cost you to replace the entire tran...   Aug 12 2016, 11:37 AM
mlindner   Mike...are you sure they are cracks, a lot of cast...   Aug 12 2016, 10:55 AM
mb911   They are magnesium. I weld 911 fans and housings w...   Aug 12 2016, 11:22 AM
MikaM   I'm quite sure :welder: https://pix.sfly.com...   Aug 12 2016, 11:29 AM
Mark Henry   weqTWwaaL0g   Aug 12 2016, 12:14 PM
MikaM   weqTWwaaL0g Thanks :D   Aug 12 2016, 12:40 PM
76-914   I have a case that you can have for the price of s...   Aug 12 2016, 01:02 PM
stugray   I have a case that you can have for the price of ...   Aug 13 2016, 12:49 PM
MikaM   PM send :)   Aug 13 2016, 08:23 AM
oldie914   I also have a case you can have. Shipping from Ger...   Aug 14 2016, 02:13 AM
MikaM   I also have a case you can have. Shipping from Ge...   Aug 14 2016, 03:14 AM
restore2seater   I also have a case you can have. Shipping from G...   Aug 15 2016, 08:22 AM
Dave_Darling   R&P == Ring and pinion. Where the pinion gear...   Aug 14 2016, 11:02 PM
porschetub   Drill holes at the end of the cracks and keep usin...   Aug 14 2016, 11:23 PM
MikaM   I was talking to 911 specialist today whit this is...   Aug 15 2016, 01:43 PM
- Lo-Fi Version Time is now: 3rd March 2026 - 08:51 AM
