| MikaM |
Aug 11 2016, 10:42 AM
Newbie ![]() Group: Members Posts: 8 Joined: 2-November 14 From: Finland Member No.: 18,080 Region Association: Europe |
I need information how to weld gearbox 914/-70, mixture or welding instructions (IMG:style_emoticons/default/smile.gif) Mine has some cranks near the starter motor..
Thank you (IMG:style_emoticons/default/smile.gif) -Mika |
| Dave_Darling |
Aug 14 2016, 11:02 PM
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,326 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California
R&P == Ring and pinion. Where the pinion gear on the counter-shaft meshes with the big ring gear attached to the differential.
--DD |
MikaM 914 gearbox metal mixture Aug 11 2016, 10:42 AM
bretth Welding Aluminum is not easy. I have seen pros scr... Aug 11 2016, 12:10 PM
Dave_Darling Isn't the transmission case a magnesium-alumin... Aug 11 2016, 12:17 PM
bretth
Isn't the transmission case a magnesium-alumi... Aug 12 2016, 08:27 AM
Beebo Kanelle http://www.locknstitch.com Aug 11 2016, 12:50 PM
Mark Henry Mag is hard to weld and it warps, you can do it wi... Aug 11 2016, 01:10 PM
MikaM Thanks :) I'll try to get it welded in some sp... Aug 12 2016, 04:18 AM
Krieger What would it cost you to replace the entire trann... Aug 12 2016, 09:02 AM
stugray
What would it cost you to replace the entire tran... Aug 12 2016, 11:31 AM
MikaM
What would it cost you to replace the entire tran... Aug 12 2016, 11:37 AM
mlindner Mike...are you sure they are cracks, a lot of cast... Aug 12 2016, 10:55 AM
mb911 They are magnesium. I weld 911 fans and housings w... Aug 12 2016, 11:22 AM
MikaM I'm quite sure :welder:
https://pix.sfly.com... Aug 12 2016, 11:29 AM
Mark Henry weqTWwaaL0g Aug 12 2016, 12:14 PM
MikaM
weqTWwaaL0g
Thanks :D Aug 12 2016, 12:40 PM
76-914 I have a case that you can have for the price of s... Aug 12 2016, 01:02 PM
stugray
I have a case that you can have for the price of ... Aug 13 2016, 12:49 PM
MikaM PM send :) Aug 13 2016, 08:23 AM
oldie914 I also have a case you can have. Shipping from Ger... Aug 14 2016, 02:13 AM
MikaM
I also have a case you can have. Shipping from Ge... Aug 14 2016, 03:14 AM
restore2seater
I also have a case you can have. Shipping from G... Aug 15 2016, 08:22 AM
porschetub Drill holes at the end of the cracks and keep usin... Aug 14 2016, 11:23 PM
MikaM I was talking to 911 specialist today whit this is... Aug 15 2016, 01:43 PM![]() ![]() |
Lo-Fi Version | Time is now: 3rd March 2026 - 07:22 AM |
