> 914 gearbox metal mixture
MikaM
post Aug 11 2016, 10:42 AM
Region Association: Europe
I need information how to weld gearbox 914/-70, mixture or welding instructions (IMG:style_emoticons/default/smile.gif) Mine has some cranks near the starter motor..
Thank you (IMG:style_emoticons/default/smile.gif)
-Mika
oldie914
post Aug 14 2016, 02:13 AM
I also have a case you can have. Shipping from Germany to Finnland would cost about Euro 30. If you are interested, I will send pictures.
Keep in mind you will need to readjust the R&P if you change the case. Need to set pinion depth, differential bearing preload and backlash.
MikaM
post Aug 14 2016, 03:14 AM
QUOTE(oldie914 @ Aug 14 2016, 11:13 AM) *
What R&P mean? I sent you PM (IMG:style_emoticons/default/smile.gif)
restore2seater
post Aug 15 2016, 08:22 AM
Future 914 copilot.
QUOTE(MikaM @ Aug 14 2016, 04:14 AM) *
R&P stands for Ring and Pinion. The differential gear set needs to be set up for the case it will be installed in.
MikaM   914 gearbox metal mixture   Aug 11 2016, 10:42 AM
bretth   Welding Aluminum is not easy. I have seen pros scr...   Aug 11 2016, 12:10 PM
Dave_Darling   Isn't the transmission case a magnesium-alumin...   Aug 11 2016, 12:17 PM
bretth   Isn't the transmission case a magnesium-alumi...   Aug 12 2016, 08:27 AM
Beebo Kanelle   http://www.locknstitch.com   Aug 11 2016, 12:50 PM
Mark Henry   Mag is hard to weld and it warps, you can do it wi...   Aug 11 2016, 01:10 PM
MikaM   Thanks :) I'll try to get it welded in some sp...   Aug 12 2016, 04:18 AM
Krieger   What would it cost you to replace the entire trann...   Aug 12 2016, 09:02 AM
stugray   What would it cost you to replace the entire tran...   Aug 12 2016, 11:31 AM
MikaM   What would it cost you to replace the entire tran...   Aug 12 2016, 11:37 AM
mlindner   Mike...are you sure they are cracks, a lot of cast...   Aug 12 2016, 10:55 AM
mb911   They are magnesium. I weld 911 fans and housings w...   Aug 12 2016, 11:22 AM
MikaM   I'm quite sure :welder: https://pix.sfly.com...   Aug 12 2016, 11:29 AM
Mark Henry   weqTWwaaL0g   Aug 12 2016, 12:14 PM
MikaM   weqTWwaaL0g Thanks :D   Aug 12 2016, 12:40 PM
76-914   I have a case that you can have for the price of s...   Aug 12 2016, 01:02 PM
stugray   I have a case that you can have for the price of ...   Aug 13 2016, 12:49 PM
MikaM   PM send :)   Aug 13 2016, 08:23 AM
oldie914   I also have a case you can have. Shipping from Ger...   Aug 14 2016, 02:13 AM
MikaM   I also have a case you can have. Shipping from Ge...   Aug 14 2016, 03:14 AM
restore2seater   I also have a case you can have. Shipping from G...   Aug 15 2016, 08:22 AM
Dave_Darling   R&P == Ring and pinion. Where the pinion gear...   Aug 14 2016, 11:02 PM
porschetub   Drill holes at the end of the cracks and keep usin...   Aug 14 2016, 11:23 PM
MikaM   I was talking to 911 specialist today whit this is...   Aug 15 2016, 01:43 PM
- Lo-Fi Version Time is now: 3rd March 2026 - 07:21 AM
