| TX914 |
Jul 1 2016, 06:14 AM
Alan-B ![]() ![]() Group: Members Posts: 177 Joined: 27-July 14 From: USA Member No.: 17,689 Region Association: None
Went for a short run around the neighborhood and stopped for gas. When I restarted there was a terrible scraping noise so I shut it off immediately. Sounded to me like a piece of engine tin or casing scraping on the impeller…
Tried restarting a couple of times with same result. Clutch in/out made no difference, and I was afraid to rev it. Oil level okay, and nothing loose in/around the impeller. I decided to drive it gently away to the side so I could tow it home for closer inspection. Restarted and drove in reverse for a few feet which made no difference, but then pulling forward for a few feet the scraping suddenly stopped. All seemed normal again so I drove it home – it idled fine, had good power and haven’t heard the noise since. I’m looking for ideas as to what the scraping sound might have been. Anyone experienced that before? It’s a ’76 with stock FI 2.0. It does have a relatively new starter. |
| TheCabinetmaker |
Aug 15 2016, 06:23 PM
I drive my car everyday ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,378 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
I'm old too, but starter looks right to me. What do you see wrong Rich?
TX914 Terrible Scraping Noise Jul 1 2016, 06:14 AM
ThePaintedMan Make sure there is nothing down by the impeller. D... Jul 1 2016, 06:17 AM
TX914 George, Thanks for the ideas. Flashlight and mirro... Jul 1 2016, 08:06 AM
stugray "New Starter"?
Is it a stock starter or... Jul 1 2016, 06:31 AM
TX914 Stugray, that's a stock starter (SR17x I think... Jul 1 2016, 08:12 AM
The Cabinetmaker I experienced that exact same thing two weeks ago.... Jul 1 2016, 10:17 AM
TX914 Thanks for the reply. Will definitely check that o... Jul 1 2016, 10:49 AM
injunmort i experienced the same situation, make sure your e... Jul 1 2016, 05:51 PM
TX914
i experienced the same situation, make sure your ... Jul 3 2016, 06:20 AM
TX914 Finally got time to remove the starter to see if t... Aug 15 2016, 03:29 PM
r_towle Maybe I'm getting old , well ok...I am. That s... Aug 15 2016, 06:10 PM
Garland Fan belt frayed, slapped, and a peice flew off? Ch... Aug 15 2016, 07:54 PM
porschetub what ever was causing the noise has spat out hopef... Aug 15 2016, 08:32 PM![]() ![]() |
Lo-Fi Version | Time is now: 26th July 2026 - 01:01 PM |
