Cost of Rebuilding 6 cyl. Carbs |
xsurfer |
Aug 21 2016, 09:01 AM
Member Group: Members Posts: 279 Joined: 4-April 06 From: La Canada, CA Member No.: 5,818 |
What is a average cost of rebuilding stock weber carbs for a six cyl?
The prices seem to range from to 250.00 ea. to the moon. Thanks Gene |
toolguy |
Aug 21 2016, 11:16 AM
Senior Member Group: Members Posts: 1,270 Joined: 2-April 11 From: San Diego / El Cajon Member No.: 12,889 Region Association: Southern California |
As previously indicated, cost depend on level of rebuild. . which to me
mean complete disassemble, remove all the galley plugs to insure passages are clear of obstructions / corrosion. Throttle shafts in 40 year old Webbers may often need bushings which is $$$ more. . parts can be estimated but labor and machine work wont be known until you get them apart. and how good they are to start with. . It would not be out of the ordinary for them to cost close to $2000 for a professional level rebuild. Just swapping gaskets and jets is another matter. . cheaper of course, but may not fix the root case of 40 year old carburetor issues. And when I do them, I hot run them on a test motor. . That way I know there are no issues, and have the balance and jetting close to start with. . Makes life much simpler once they are back on their motor. . Wonder what a 'Pro Shop' would charge for this. . |
Lo-Fi Version | Time is now: 16th June 2024 - 10:05 AM |
