> Has anyone installed a universal chassis harness?
zach914v8
post Aug 22 2016, 10:24 PM
My chassis wire harness is garbage. Recently the wires have started to disintegrate and I have shorts everywhere. When I fix one spot somewhere else fails, and I have to band-aid more crap. I am starting to worry about my car catching fire, and I'm tired of it.
My car is a 74 with a carbed v8. I'm not thrilled about the prospect of buying a used 40yo harness either.
My question is have any of you out there installed a painless/universal chassis harness in your cars?
If so how did you wire the dimmer/light switch/pop up headlights and 2 speed wipers?
What problems did you come across, and what fix it?
Thanks
Zach
zach914v8   Has anyone installed a universal chassis harness?   Aug 22 2016, 10:24 PM
whitetwinturbo   Hi Zach, What is causing the brittle conditions? ...   Aug 22 2016, 10:37 PM
Chris914n6   There is a guy on ebay that has a good portion of ...   Aug 22 2016, 11:44 PM
zach914v8   I have owned the car for 17 years. I bought it whe...   Aug 23 2016, 06:11 AM
Jeff Bowlsby   A universal harness has no chance of working. The...   Aug 23 2016, 10:09 AM
SixerJ   A universal harness has no chance of working. Th...   Aug 23 2016, 03:31 PM
2mAn   I second Jeffs recommendation, but if the only two...   Aug 23 2016, 10:27 AM
zach914v8   I have seen pictures of the GT manual headlights, ...   Aug 23 2016, 11:23 AM
Jeff Bowlsby   Its pretty simple. Study the factory wiring schem...   Aug 23 2016, 11:36 AM
zach914v8   Resale is of no concern whatsoever to me, and I do...   Aug 23 2016, 11:54 AM
jd74914   I don't see any problem with using a universal...   Aug 23 2016, 12:14 PM
zach914v8   I don't see any problem with using a universa...   Aug 23 2016, 01:10 PM
ejharris   I don't see any problem with using a universa...   Aug 24 2016, 06:42 AM
zach914v8   I don't see any problem with using a univers...   Aug 24 2016, 07:14 AM
jd74914   [quote name='ejharris' post='2389416' date='Aug 2...   Aug 24 2016, 07:36 AM
zach914v8   Reading up on the infinity box. Very cool stuff bu...   Aug 24 2016, 10:52 AM
Cracker   Tony, got any build pics of your wiring? Really ...   Aug 24 2016, 11:03 AM
zach914v8   Tony, got any build pics of your wiring? Really...   Aug 24 2016, 11:10 AM
Downunderman   My sentiment entirely. For the car I'm buildi...   Aug 23 2016, 01:31 PM
Jeff Bowlsby   Agreed. And appreciate the recognition of differe...   Aug 23 2016, 01:34 PM
mb911   Sounds like what we need to do is just make a new ...   Aug 23 2016, 02:20 PM
SirAndy   I bought a complete and unmolested chassis harness...   Aug 23 2016, 02:30 PM
Chris914n6   Why the all or nothing approach? Keep or restore t...   Aug 23 2016, 03:24 PM
zach914v8   I will try to address everyone here... Chris914n6...   Aug 24 2016, 06:57 AM
matthepcat   I suggest reaching out to fasthonda to get more de...   Aug 24 2016, 12:25 PM
Mike Bellis   It can be done. Not easy but can be done. The bigg...   Aug 23 2016, 04:05 PM
matthepcat   I believe member fasthonda put in an 8 circuit uni...   Aug 23 2016, 04:27 PM
Cory M   Not much info on this in the Porsche world. All Po...   Aug 23 2016, 05:26 PM
Cracker   Not exactly answering directly what you're ask...   Aug 24 2016, 07:05 AM
Cracker   Thank you Zach...only made one set and hopefully n...   Aug 24 2016, 12:28 PM
BIGKAT_83   I've helped with one and will do another prett...   Aug 24 2016, 12:58 PM
Cracker   ...should've known Bob had this down pat! ...   Aug 24 2016, 01:04 PM
zach914v8   This from c contact? So is this like a monetary re...   Aug 24 2016, 01:23 PM
zach914v8   or is it something like this?   Aug 24 2016, 01:27 PM
Mike Bellis   A simple DPDT relay can operate the pop up lights....   Aug 24 2016, 05:33 PM
zach914v8   A simple DPDT relay can operate the pop up lights...   Aug 24 2016, 06:12 PM
Mike Bellis   A simple DPDT relay can operate the pop up light...   Aug 24 2016, 06:27 PM
zach914v8   [quote name='zach914v8' post='2389701' date='Aug ...   Aug 24 2016, 06:39 PM
arkitect   Zach, please keep me in the loop on your solution ...   Mar 10 2017, 10:24 PM
tygaboy   I need a harness for my Build-Off Challenge projec...   Mar 13 2017, 10:12 AM
jd74914   I need a harness for my Build-Off Challenge proje...   Mar 13 2017, 10:41 AM
tygaboy   I need a harness for my Build-Off Challenge proj...   Mar 13 2017, 11:23 AM
- Lo-Fi Version Time is now: 2nd April 2026 - 09:36 AM
