| rgalla9146 |
Sep 23 2013, 08:31 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,950 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None
Does the AAR on a 73 2.0 ever close completely ?
Does it operate on 12V only or does it rely on engine ambient temp to operate as well ? I have a high idle after adjusting timing ( with known factory timing marks ) and checking all areas for vacuum leaks. If I cap the AAR hose the idle is normal and there is adjustment left on the idle screw. The points plate moves freely with vacuum in both directions. TIA |
| Dave_Darling |
Sep 24 2013, 09:57 PM
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,335 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California
If that fails (hopefully it won't) after several tries, you can pry the lip of the can open from around the top part. The top, valve, and spring all slide out. You may be able to use a slot-head screwdriver on the bottom of the valve to turn it, freeing it up.
--DD |
| rgalla9146 |
Sep 25 2013, 10:44 AM
If that fails (hopefully it won't) after several tries, you can pry the lip of the can open from around the top part. The top, valve, and spring all slide out. You may be able to use a slot-head screwdriver on the bottom of the valve to turn it, freeing it up. --DD OK, pried it open pretty cleanly. All looks pretty simple. Removed the bi-metallic coil That shaft is #@%#&($ waaay stuck ! Just to be sure..... the pie shape piece is the fixed part right ? Break out the torch ? |
| rgalla9146 |
Sep 25 2013, 10:57 AM
If that fails (hopefully it won't) after several tries, you can pry the lip of the can open from around the top part. The top, valve, and spring all slide out. You may be able to use a slot-head screwdriver on the bottom of the valve to turn it, freeing it up. --DD OK, pried it open pretty cleanly. All looks pretty simple. Removed the bi-metallic coil That shaft is #@%#&($ waaay stuck ! Just to be sure..... the pie shape piece is the fixed part right ? Break out the torch ? Never mind. It freed up. I didn't want to be too aggressive and ruin it. Thanks all..... now to see how well it works ! |
| 9fourteen14 |
Aug 23 2016, 01:21 PM
PORSCHE LUVA ![]() ![]() Group: Members Posts: 135 Joined: 5-July 15 From: boston Member No.: 18,920 Region Association: North East States |
If that fails (hopefully it won't) after several tries, you can pry the lip of the can open from around the top part. The top, valve, and spring all slide out. You may be able to use a slot-head screwdriver on the bottom of the valve to turn it, freeing it up. --DD OK, pried it open pretty cleanly. All looks pretty simple. Removed the bi-metallic coil That shaft is #@%#&($ waaay stuck ! Just to be sure..... the pie shape piece is the fixed part right ? Break out the torch ? Never mind. It freed up. I didn't want to be too aggressive and ruin it. Thanks all..... now to see how well it works ! Wanna sell me one. I have a 74 2.0 I need one Niece 914 luva |
rgalla9146 Auxilary air regulator Sep 23 2013, 08:31 PM
dangrouche
... Sep 23 2013, 08:35 PM
r_towle It's a coiled up spring.
Blast a can of pb bl... Sep 23 2013, 09:10 PM
76-914 Remove it and as Rich said PB it or WD40 it. Placi... Sep 24 2013, 09:08 AM
worn
... Sep 24 2013, 10:21 AM
rgalla9146
Does the AAR on a 73 2.0 ever close completely ?... Sep 24 2013, 04:24 PM
442nd914s I found this awhile back. Maybe it might help some... Sep 25 2013, 12:23 PM
rgalla9146
I found this awhile back. Maybe it might help som... Sep 25 2013, 09:28 PM
Dave_Darling The cylinder with a slit in it is the "rotary... Sep 27 2013, 08:20 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 10:02 AM |
