> Has anyone installed a universal chassis harness?
zach914v8
post Aug 22 2016, 10:24 PM
My chassis wire harness is garbage. Recently the wires have started to disintegrate and I have shorts everywhere. When I fix one spot somewhere else fails, and I have to band-aid more crap. I am starting to worry about my car catching fire, and I'm tired of it.
My car is a 74 with a carbed v8. I'm not thrilled about the prospect of buying a used 40yo harness either.
My question is have any of you out there installed a painless/universal chassis harness in your cars?
If so how did you wire the dimmer/light switch/pop up headlights and 2 speed wipers?
What problems did you come across, and what fix it?
Thanks
Zach
Mike Bellis
post Aug 23 2016, 04:05 PM
Resident Electrician
It can be done. Not easy but can be done. The biggest challenge are the turn signals and brake lights. The 914 separates these into their own circuits and the universal kits have a turn/brake light common circuit. The control for which is part of the turn signal stalk. They actually run the brake light circuit into the stalk to cut off from the turn when the stalk is rotated.
I would need to study the 914 stalk diagram to determine if it could be used or modified to work. It might be easier to keep the 914 turn signal circuit in place and graft it into the universal kit.
Anything can be done with enough knowledge...
zach914v8   Has anyone installed a universal chassis harness?   Aug 22 2016, 10:24 PM
whitetwinturbo   Hi Zach, What is causing the brittle conditions? ...   Aug 22 2016, 10:37 PM
Chris914n6   There is a guy on ebay that has a good portion of ...   Aug 22 2016, 11:44 PM
zach914v8   I have owned the car for 17 years. I bought it whe...   Aug 23 2016, 06:11 AM
Jeff Bowlsby   A universal harness has no chance of working. The...   Aug 23 2016, 10:09 AM
SixerJ   A universal harness has no chance of working. Th...   Aug 23 2016, 03:31 PM
2mAn   I second Jeffs recommendation, but if the only two...   Aug 23 2016, 10:27 AM
zach914v8   I have seen pictures of the GT manual headlights, ...   Aug 23 2016, 11:23 AM
Jeff Bowlsby   Its pretty simple. Study the factory wiring schem...   Aug 23 2016, 11:36 AM
zach914v8   Resale is of no concern whatsoever to me, and I do...   Aug 23 2016, 11:54 AM
jd74914   I don't see any problem with using a universal...   Aug 23 2016, 12:14 PM
zach914v8   I don't see any problem with using a universa...   Aug 23 2016, 01:10 PM
ejharris   I don't see any problem with using a universa...   Aug 24 2016, 06:42 AM
zach914v8   I don't see any problem with using a univers...   Aug 24 2016, 07:14 AM
jd74914   [quote name='ejharris' post='2389416' date='Aug 2...   Aug 24 2016, 07:36 AM
zach914v8   Reading up on the infinity box. Very cool stuff bu...   Aug 24 2016, 10:52 AM
Cracker   Tony, got any build pics of your wiring? Really ...   Aug 24 2016, 11:03 AM
zach914v8   Tony, got any build pics of your wiring? Really...   Aug 24 2016, 11:10 AM
Downunderman   My sentiment entirely. For the car I'm buildi...   Aug 23 2016, 01:31 PM
Jeff Bowlsby   Agreed. And appreciate the recognition of differe...   Aug 23 2016, 01:34 PM
mb911   Sounds like what we need to do is just make a new ...   Aug 23 2016, 02:20 PM
SirAndy   I bought a complete and unmolested chassis harness...   Aug 23 2016, 02:30 PM
Chris914n6   Why the all or nothing approach? Keep or restore t...   Aug 23 2016, 03:24 PM
zach914v8   I will try to address everyone here... Chris914n6...   Aug 24 2016, 06:57 AM
matthepcat   I suggest reaching out to fasthonda to get more de...   Aug 24 2016, 12:25 PM
Mike Bellis   It can be done. Not easy but can be done. The bigg...   Aug 23 2016, 04:05 PM
matthepcat   I believe member fasthonda put in an 8 circuit uni...   Aug 23 2016, 04:27 PM
Cory M   Not much info on this in the Porsche world. All Po...   Aug 23 2016, 05:26 PM
Cracker   Not exactly answering directly what you're ask...   Aug 24 2016, 07:05 AM
Cracker   Thank you Zach...only made one set and hopefully n...   Aug 24 2016, 12:28 PM
BIGKAT_83   I've helped with one and will do another prett...   Aug 24 2016, 12:58 PM
Cracker   ...should've known Bob had this down pat! ...   Aug 24 2016, 01:04 PM
zach914v8   This from c contact? So is this like a monetary re...   Aug 24 2016, 01:23 PM
zach914v8   or is it something like this?   Aug 24 2016, 01:27 PM
Mike Bellis   A simple DPDT relay can operate the pop up lights....   Aug 24 2016, 05:33 PM
zach914v8   A simple DPDT relay can operate the pop up lights...   Aug 24 2016, 06:12 PM
Mike Bellis   A simple DPDT relay can operate the pop up light...   Aug 24 2016, 06:27 PM
zach914v8   [quote name='zach914v8' post='2389701' date='Aug ...   Aug 24 2016, 06:39 PM
arkitect   Zach, please keep me in the loop on your solution ...   Mar 10 2017, 10:24 PM
tygaboy   I need a harness for my Build-Off Challenge projec...   Mar 13 2017, 10:12 AM
jd74914   I need a harness for my Build-Off Challenge proje...   Mar 13 2017, 10:41 AM
tygaboy   I need a harness for my Build-Off Challenge proj...   Mar 13 2017, 11:23 AM
- Lo-Fi Version Time is now: 2nd April 2026 - 07:59 AM
