6.5s under standard rear arches, Will they fit.... or will they rub? |
23e Heure |
Aug 24 2016, 03:08 AM
Busy overtaking 911s Group: Members Posts: 323 Joined: 13-August 15 From: London Member No.: 19,057 Region Association: England |
I am planning to send my car to a shop over the winter to have GT arches welded, and then it will be rolling on 7s and 8s... or 8s and 9s (I am still pondering that choice).
In the meantime I have already got local buyers waiting to take the set of 6x15 fuchs that are currently fitted to the car. In the meantime a friend has offered to lend me a set of steelies to roll the car on. This will only be to drive the car a couple of hundred miles between home and the shops doing the work. The fronts would be 5.5x15, so no worries there. But the rears he is offering are 6.5x15s. Offset is 36. And they are fitted with 195/60 rubber. So the question is: w Would they rub the standard narrow rear arches? If so, only a tiny bit? Or lots? As I'm cutting the arches over the winter I am not too worried by rubbing those a bit. But I would worry about trashing my buddies tyres! The loan wheels are a 2 hours round trip from me, so I can't just fit and try them out, hence me askig the Oracle of the forum. Thanks guys! |
GeorgeRud |
Aug 24 2016, 09:42 AM
Advanced Member Group: Members Posts: 3,725 Joined: 27-July 05 From: Chicagoland Member No.: 4,482 Region Association: Upper MidWest |
Actually, if you have alloy lug nuts (as used with Fuchs), you will need to get steel lugnuts with open ends as the alloy one may not seat the steel wheels completely.
mepstein |
Aug 24 2016, 10:21 AM
914-6 GT in waiting Group: Members Posts: 19,319 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Actually, if you have alloy lug nuts (as used with Fuchs), you will need to get steel lugnuts with open ends as the alloy one may not seat the steel wheels completely. (IMG:style_emoticons/default/agree.gif) better to be prepared and the steel ones are cheap. |
Lo-Fi Version | Time is now: 13th June 2024 - 02:26 AM |
