| zach914v8 |
Aug 22 2016, 10:24 PM
Member ![]() ![]() Group: Members Posts: 216 Joined: 26-November 10 From: Houston Member No.: 12,426 Region Association: Southwest Region |
My chassis wire harness is garbage. Recently the wires have started to disintegrate and I have shorts everywhere. When I fix one spot somewhere else fails, and I have to band-aid more crap. I am starting to worry about my car catching fire, and I'm tired of it.
My car is a 74 with a carbed v8. I'm not thrilled about the prospect of buying a used 40yo harness either. My question is have any of you out there installed a painless/universal chassis harness in your cars? If so how did you wire the dimmer/light switch/pop up headlights and 2 speed wipers? What problems did you come across, and what fix it? Thanks Zach |
| BIGKAT_83 |
Aug 24 2016, 12:58 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,800 Joined: 25-January 03 From: Way down south Bogart,GA Member No.: 194 Region Association: South East States
I've helped with one and will do another pretty soon the headlights are really no trouble, but did add a relay with a set of form C contacts.
Bob |
zach914v8 Has anyone installed a universal chassis harness? Aug 22 2016, 10:24 PM
whitetwinturbo Hi Zach,
What is causing the brittle conditions? ... Aug 22 2016, 10:37 PM
Chris914n6 There is a guy on ebay that has a good portion of ... Aug 22 2016, 11:44 PM
zach914v8 I have owned the car for 17 years. I bought it whe... Aug 23 2016, 06:11 AM
Jeff Bowlsby A universal harness has no chance of working. The... Aug 23 2016, 10:09 AM
SixerJ
A universal harness has no chance of working. Th... Aug 23 2016, 03:31 PM
2mAn I second Jeffs recommendation, but if the only two... Aug 23 2016, 10:27 AM
zach914v8 I have seen pictures of the GT manual headlights, ... Aug 23 2016, 11:23 AM
Jeff Bowlsby Its pretty simple. Study the factory wiring schem... Aug 23 2016, 11:36 AM
zach914v8 Resale is of no concern whatsoever to me, and I do... Aug 23 2016, 11:54 AM
jd74914 I don't see any problem with using a universal... Aug 23 2016, 12:14 PM
zach914v8
I don't see any problem with using a universa... Aug 23 2016, 01:10 PM
ejharris
I don't see any problem with using a universa... Aug 24 2016, 06:42 AM
zach914v8
I don't see any problem with using a univers... Aug 24 2016, 07:14 AM
jd74914
[quote name='ejharris' post='2389416' date='Aug 2... Aug 24 2016, 07:36 AM
zach914v8 Reading up on the infinity box. Very cool stuff bu... Aug 24 2016, 10:52 AM
Cracker
Tony, got any build pics of your wiring? Really ... Aug 24 2016, 11:03 AM
zach914v8
Tony, got any build pics of your wiring? Really... Aug 24 2016, 11:10 AM
Downunderman My sentiment entirely. For the car I'm buildi... Aug 23 2016, 01:31 PM
Jeff Bowlsby Agreed. And appreciate the recognition of differe... Aug 23 2016, 01:34 PM
mb911 Sounds like what we need to do is just make a new ... Aug 23 2016, 02:20 PM
SirAndy I bought a complete and unmolested chassis harness... Aug 23 2016, 02:30 PM
Chris914n6 Why the all or nothing approach? Keep or restore t... Aug 23 2016, 03:24 PM
zach914v8 I will try to address everyone here...
Chris914n6... Aug 24 2016, 06:57 AM
matthepcat I suggest reaching out to fasthonda to get more de... Aug 24 2016, 12:25 PM
Mike Bellis It can be done. Not easy but can be done. The bigg... Aug 23 2016, 04:05 PM
matthepcat I believe member fasthonda put in an 8 circuit uni... Aug 23 2016, 04:27 PM
Cory M Not much info on this in the Porsche world. All Po... Aug 23 2016, 05:26 PM
Cracker Not exactly answering directly what you're ask... Aug 24 2016, 07:05 AM
Cracker Thank you Zach...only made one set and hopefully n... Aug 24 2016, 12:28 PM
Cracker ...should've known Bob had this down pat! ... Aug 24 2016, 01:04 PM
zach914v8 This from c contact? So is this like a monetary re... Aug 24 2016, 01:23 PM
zach914v8 or is it something like this?
Aug 24 2016, 01:27 PM
Mike Bellis A simple DPDT relay can operate the pop up lights.... Aug 24 2016, 05:33 PM
zach914v8
A simple DPDT relay can operate the pop up lights... Aug 24 2016, 06:12 PM
Mike Bellis
A simple DPDT relay can operate the pop up light... Aug 24 2016, 06:27 PM
zach914v8
[quote name='zach914v8' post='2389701' date='Aug ... Aug 24 2016, 06:39 PM
arkitect Zach,
please keep me in the loop on your solution ... Mar 10 2017, 10:24 PM
tygaboy I need a harness for my Build-Off Challenge projec... Mar 13 2017, 10:12 AM
jd74914
I need a harness for my Build-Off Challenge proje... Mar 13 2017, 10:41 AM
tygaboy
I need a harness for my Build-Off Challenge proj... Mar 13 2017, 11:23 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 09:36 AM |
