> FUEL PUMP REPLACEMENT, any afforable options?
chazt74914
post Sep 6 2016, 09:28 AM
CHAZT54
So I had replaced all the old frayed fuel lines under my '74 2.0 since they were starting to leak. Now that I have finished, (bitch of a job under that RH side) the electric fuel pump has started seeping fuel from the electrical connect terminal area.
This original style pump looks to be a sealed unit and the only replacement option I have found is a rebuilt from Auto Atlanta @ $400 exchange. There are other elect pumps out there for less but are designated for carb units. I still have the D-jet system in place and working well so I am not interested in converting to carbs.
Anybody out there know of a less-expensive option?
drewvw
post Sep 6 2016, 11:13 AM
new england car guy
I did mine last year for a 1.7 with the following based on some archive research here:
+ Bosch Fuel Pump Part Number. BSH 69133
8mm OD on the inlet, 12mm OD on the outlet
+ Napa Fuel Filter 3274
10 mm inlet, 13mm outlet
+ Piece of Rubber. Reuse the bracket from the old pump, you'll find that it's too big. I was able to get mine to work by wrapping the pump with a piece of rubber.
Can be purchased at NAPA or online. Worked well. There are a few different ways to do the filter but the pump was inexpensive and is a 2 port.
chazt74914   FUEL PUMP REPLACEMENT   Sep 6 2016, 09:28 AM
MikeM   They often come up for sale here. I would try Bruc...   Sep 6 2016, 10:01 AM
chazt74914   They often come up for sale here. I would try Bru...   Sep 6 2016, 10:35 AM
JawjaPorsche   NAPA has a Bosch Fuel Pump that will fit: Part Nu...   Sep 6 2016, 10:23 AM
chazt74914   NAPA has a Bosch Fuel Pump that will fit: Part N...   Sep 6 2016, 10:36 AM
87m491   You might want to check Rock Auto as well. <...   Sep 6 2016, 10:55 AM
chazt74914   NAPA has a Bosch Fuel Pump that will fit: Part N...   Sep 6 2016, 12:31 PM
JawjaPorsche   NAPA has a Bosch Fuel Pump that will fit: Part ...   Sep 7 2016, 11:24 AM
rgalla9146   [quote name='JawjaPorsche' post='239...   Sep 7 2016, 12:47 PM
JawjaPorsche   [quote name='JawjaPorsche' date='Sep ...   Sep 7 2016, 01:34 PM
drewvw   I did mine last year for a 1.7 with the following ...   Sep 6 2016, 11:13 AM
87m491   "8mm OD inlet, 12mm OD outlet"? on mine ...   Sep 8 2016, 01:55 PM
PlantMan   Airtek is another options which you can get from A...   Sep 6 2016, 12:46 PM
PlantMan   Me too on the fire wall. Easier to access.   Sep 7 2016, 11:31 AM
ClayPerrine   Airtex E8445 or equivalent. Same pressure and vo...   Sep 7 2016, 11:41 AM
boxsterfan   Airtex E8445 or equivalent. Same pressure and v...   Sep 7 2016, 01:13 PM
87m491   I bet with a little persuasion you can get the sam...   Sep 8 2016, 02:00 PM
ClayPerrine   I bet with a little persuasion you can get the sa...   Jun 30 2023, 08:33 AM
napasteve   I copied what JawjaPorsche did. Works great.   Sep 7 2016, 12:11 PM
Tom_T   Hey Folks, while those engine bay firewall install...   Sep 8 2016, 12:26 PM
JawjaPorsche   I would interested to see if anyone has a vapor lo...   Sep 8 2016, 12:46 PM
Tom_T   I would interested to see if anyone has a vapor l...   Sep 8 2016, 12:56 PM
ctc911ctc   '74, 2.0 all stock - 25K org miles, New Englan...   Jun 30 2023, 06:08 AM
- Lo-Fi Version Time is now: 25th August 2025 - 11:43 PM
