> FUEL PUMP REPLACEMENT, any afforable options?
chazt74914
post Sep 6 2016, 09:28 AM
CHAZT54
So I had replaced all the old frayed fuel lines under my '74 2.0 since they were starting to leak. Now that I have finished, (bitch of a job under that RH side) the electric fuel pump has started seeping fuel from the electrical connect terminal area.
This original style pump looks to be a sealed unit and the only replacement option I have found is a rebuilt from Auto Atlanta @ $400 exchange. There are other elect pumps out there for less but are designated for carb units. I still have the D-jet system in place and working well so I am not interested in converting to carbs.
Anybody out there know of a less-expensive option?
JawjaPorsche
post Sep 8 2016, 12:46 PM
I would interested to see if anyone has a vapor lock issue after locating their fuel pump to the firewall.
Where it was originally was a terrible place to place the fuel pump. It got very hot there because it was next to the heat exchanger! Plus no air movement!
I drove my 914 from Georgia to California in Summer of 1975. Outside Phoenix, it vapor locked because it was 110 degrees. State Patrol stopped by and said it let it cool and when it starts to run the heater to pull heat out of the area. So driving in 110 degree heat with heater on! But no vapor lock!
Moved mine twenty years ago to firewall and my vapor lock issues disappeared. I bought my 914 new in 1973.
I remember calling my local Porsche dealership and spoke to service manager and he said to move it to the FIREWALL! I guess he did not see the service bulletin. Of course, that was twenty years ago even back then!
chazt74914   FUEL PUMP REPLACEMENT   Sep 6 2016, 09:28 AM
MikeM   They often come up for sale here. I would try Bruc...   Sep 6 2016, 10:01 AM
chazt74914   They often come up for sale here. I would try Bru...   Sep 6 2016, 10:35 AM
JawjaPorsche   NAPA has a Bosch Fuel Pump that will fit: Part Nu...   Sep 6 2016, 10:23 AM
chazt74914   NAPA has a Bosch Fuel Pump that will fit: Part N...   Sep 6 2016, 10:36 AM
87m491   You might want to check Rock Auto as well. <...   Sep 6 2016, 10:55 AM
chazt74914   NAPA has a Bosch Fuel Pump that will fit: Part N...   Sep 6 2016, 12:31 PM
JawjaPorsche   NAPA has a Bosch Fuel Pump that will fit: Part ...   Sep 7 2016, 11:24 AM
rgalla9146   [quote name='JawjaPorsche' post='239...   Sep 7 2016, 12:47 PM
JawjaPorsche   [quote name='JawjaPorsche' date='Sep ...   Sep 7 2016, 01:34 PM
drewvw   I did mine last year for a 1.7 with the following ...   Sep 6 2016, 11:13 AM
87m491   "8mm OD inlet, 12mm OD outlet"? on mine ...   Sep 8 2016, 01:55 PM
PlantMan   Airtek is another options which you can get from A...   Sep 6 2016, 12:46 PM
PlantMan   Me too on the fire wall. Easier to access.   Sep 7 2016, 11:31 AM
ClayPerrine   Airtex E8445 or equivalent. Same pressure and vo...   Sep 7 2016, 11:41 AM
boxsterfan   Airtex E8445 or equivalent. Same pressure and v...   Sep 7 2016, 01:13 PM
87m491   I bet with a little persuasion you can get the sam...   Sep 8 2016, 02:00 PM
ClayPerrine   I bet with a little persuasion you can get the sa...   Jun 30 2023, 08:33 AM
napasteve   I copied what JawjaPorsche did. Works great.   Sep 7 2016, 12:11 PM
Tom_T   Hey Folks, while those engine bay firewall install...   Sep 8 2016, 12:26 PM
JawjaPorsche   I would interested to see if anyone has a vapor lo...   Sep 8 2016, 12:46 PM
Tom_T   I would interested to see if anyone has a vapor l...   Sep 8 2016, 12:56 PM
ctc911ctc   '74, 2.0 all stock - 25K org miles, New Englan...   Jun 30 2023, 06:08 AM
- Lo-Fi Version Time is now: 25th August 2025 - 11:43 PM
