chazt74914 |
CHAZT54 ![]() Group: Members Posts: 18 Joined: 8-July 14 From: New London, WI Member No.: 17,600 Region Association: None ![]() |
So I had replaced all the old frayed fuel lines under my '74 2.0 since they were starting to leak. Now that I have finished, (bitch of a job under that RH side) the electric fuel pump has started seeping fuel from the electrical connect terminal area.
This original style pump looks to be a sealed unit and the only replacement option I have found is a rebuilt from Auto Atlanta @ $400 exchange. There are other elect pumps out there for less but are designated for carb units. I still have the D-jet system in place and working well so I am not interested in converting to carbs. Anybody out there know of a less-expensive option? |
ClayPerrine |
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,512 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille ![]() ![]() |
Airtex E8445 or equivalent. Same pressure and volume as the stock pump.
Available at any FLAPS. |
boxsterfan |
914's are kewl ![]() ![]() ![]() Group: Members Posts: 1,776 Joined: 6-June 03 From: San Ramon, CA Member No.: 791 Region Association: Northern California ![]() |
Airtex E8445 or equivalent. Same pressure and volume as the stock pump. Available at any FLAPS. The AirTex unit seems like the way to go, but has 8mm inlet and outlet. It would be great to find a pump that has 9.5mm inlet and outlet (plus a fuel filter with the same). Just trying to avoid the number of adapters it takes....always feels like building Frankenstein. |
87m491 |
Member ![]() ![]() Group: Members Posts: 330 Joined: 29-July 12 From: Portland, the original! Member No.: 14,731 Region Association: North East States ![]() ![]() |
I bet with a little persuasion you can get the same ID sized hose to fit both 8 and 9.5 fittings....
Lo-Fi Version | Time is now: 25th August 2025 - 11:43 PM |
