| Garland |
Sep 10 2016, 08:43 AM
Restoration Fanatic ![]() ![]() ![]() Group: Members Posts: 1,428 Joined: 8-January 04 From: ......Michigan...... Member No.: 1,535 Region Association: Upper MidWest
Trying to get #4 to stop popping from the carb. I have checked the timing, dist drive gear, intake for leaks, swapped plug wire, replaced spark plug, adjusted and balanced carbs, plugged and unpluged the vacuum port on that carb barrel. ( I leave these plugged and have no use for them) And done a valve adjustment.
Heres what Im wondering. My drive gear looks a bit off from the pictures here and in the book. But if I lift and drop, right or left its way off. The location of #1 on the cap is seen in the picture below. The engine starts right up, and runs well. Yet the popping from # 4 is killing me., If i adjust the timing it seems that I can retard it to mostly exhaust backfire. The #4 plug hole is a pit short in depth, at least it looks that way, but the plug is seating and appears to be no leakage. I think it was slightly miss threaded in the past. I am concerned that somehow I am missing the correct distributor alignment with the gear, or the gear is off, or I'm clocked wrong. Or the spark plug hole is not sealing. I have put about 100 miles on the engine, with it running like this. Seems a little rough, while cruising along at 70 almost like a intermittent miss whit that cab popping. What could be the cause of this? Any ideas of what now? Could the items Im addressing be the cause? I am going to drive this car to Okteenerfest. Mallory unilite installed. (silver tape marks #1) |
| Mark Henry |
Sep 10 2016, 10:01 AM
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada |
Look again I wasn't done editing (IMG:style_emoticons/default/biggrin.gif)
Garland Help me make it to Oktennerfest! (under my own power) Sep 10 2016, 08:43 AM
Mark Henry You have the drive 180 off but that won't caus... Sep 10 2016, 09:52 AM
Garland I'm going to try to balance the carbs out agai... Sep 10 2016, 10:00 AM
Mark Henry Looking at your linkage, well to be kind I'll ... Sep 10 2016, 10:06 AM
Garland OK, just to be sure I'm following a proper pro... Sep 10 2016, 10:07 AM
rhodyguy If you turn the idle air mixture screw on #4 in un... Sep 10 2016, 10:12 AM
Garland Got it. I'll post my results thank you. And I... Sep 10 2016, 10:22 AM
Mark Henry This is the centerpull linkage in the T4 in my bug... Sep 10 2016, 10:33 AM
Garland I've checked mine over it it has a lot of slop... Sep 10 2016, 10:49 AM
Mark Henry
I've checked mine over it it has a lot of slo... Sep 10 2016, 11:30 AM
Mark Henry If you don't have the fab skills for a center ... Sep 10 2016, 11:47 AM
rhodyguy get the new linkage. you can fight it til you... Sep 10 2016, 12:03 PM
Mblizzard I have done the fight. The CFR linkage is the way ... Sep 10 2016, 11:24 PM
Garland Still going to go with the new linkage soon. But f... Sep 11 2016, 01:00 PM![]() ![]() |
Lo-Fi Version | Time is now: 12th March 2026 - 05:16 PM |
