| Garland |
Sep 10 2016, 08:43 AM
Restoration Fanatic ![]() ![]() ![]() Group: Members Posts: 1,428 Joined: 8-January 04 From: ......Michigan...... Member No.: 1,535 Region Association: Upper MidWest
Trying to get #4 to stop popping from the carb. I have checked the timing, dist drive gear, intake for leaks, swapped plug wire, replaced spark plug, adjusted and balanced carbs, plugged and unpluged the vacuum port on that carb barrel. ( I leave these plugged and have no use for them) And done a valve adjustment.
Heres what Im wondering. My drive gear looks a bit off from the pictures here and in the book. But if I lift and drop, right or left its way off. The location of #1 on the cap is seen in the picture below. The engine starts right up, and runs well. Yet the popping from # 4 is killing me., If i adjust the timing it seems that I can retard it to mostly exhaust backfire. The #4 plug hole is a pit short in depth, at least it looks that way, but the plug is seating and appears to be no leakage. I think it was slightly miss threaded in the past. I am concerned that somehow I am missing the correct distributor alignment with the gear, or the gear is off, or I'm clocked wrong. Or the spark plug hole is not sealing. I have put about 100 miles on the engine, with it running like this. Seems a little rough, while cruising along at 70 almost like a intermittent miss whit that cab popping. What could be the cause of this? Any ideas of what now? Could the items Im addressing be the cause? I am going to drive this car to Okteenerfest. Mallory unilite installed. (silver tape marks #1) |
| Garland |
Sep 11 2016, 01:00 PM
Still going to go with the new linkage soon. But for now I adjusted the idle stops on the carburetors, adjusted the linkage to be as tight as possible, and then balance the carbs back-and-forth so I'm running it 5 on the flowmeter for each barrel. Now that they're equally working I can actually move the popping from one cylinder to another by adjusting the imbalance. Thank you for the help. And also check out this link it helped me with adjusting the carburetors.
Carburetor adjustment |
Garland Help me make it to Oktennerfest! (under my own power) Sep 10 2016, 08:43 AM
Mark Henry You have the drive 180 off but that won't caus... Sep 10 2016, 09:52 AM
Garland I'm going to try to balance the carbs out agai... Sep 10 2016, 10:00 AM
Mark Henry Look again I wasn't done editing :D Sep 10 2016, 10:01 AM
Mark Henry Looking at your linkage, well to be kind I'll ... Sep 10 2016, 10:06 AM
Garland OK, just to be sure I'm following a proper pro... Sep 10 2016, 10:07 AM
rhodyguy If you turn the idle air mixture screw on #4 in un... Sep 10 2016, 10:12 AM
Garland Got it. I'll post my results thank you. And I... Sep 10 2016, 10:22 AM
Mark Henry This is the centerpull linkage in the T4 in my bug... Sep 10 2016, 10:33 AM
Garland I've checked mine over it it has a lot of slop... Sep 10 2016, 10:49 AM
Mark Henry
I've checked mine over it it has a lot of slo... Sep 10 2016, 11:30 AM
Mark Henry If you don't have the fab skills for a center ... Sep 10 2016, 11:47 AM
rhodyguy get the new linkage. you can fight it til you... Sep 10 2016, 12:03 PM
Mblizzard I have done the fight. The CFR linkage is the way ... Sep 10 2016, 11:24 PM![]() ![]() |
Lo-Fi Version | Time is now: 12th March 2026 - 05:15 PM |
