| Frankvw |
Sep 11 2016, 10:10 AM
working on my first 914 ! ![]() ![]() ![]() Group: Members Posts: 653 Joined: 13-April 16 From: Holland, the Netherlands Member No.: 19,896 Region Association: Europe |
Hi all. I started working on my 914 and first thing was an oilchange and a new filter. Got all the parts new, and started working. How hard is an oilchange right?
All went fine untill I removed the old oilfilter...i thought a wrong one was there since it was another type then should be there, it was smaller in diameter. However... The new filter does not fit. It is too wide since it hits another part, a supportthing that hold a wheel that presses on the belt. See pics. The new bosch filter is hitting this supportbracket. This is the new filter i think is ok This filter came off. It is smaller in diameter and clears the supportbracket Can you please advice? Can i get that smaller diameter oilfilter to continue ? |
| Dion |
Sep 11 2016, 12:27 PM
RN ![]() ![]() ![]() ![]() Group: Members Posts: 2,935 Joined: 16-September 04 From: Shepherdstown, WV Member No.: 2,766 Region Association: MidAtlantic Region
I use MAHLE OC-28.
I usually had probs with the length of canister with my aftermarket BAT external oil cooler adaptor. The Mahle works best in that regard. Not sure though of clearance with the a/c pulley and diameter of canister. Maybe give it a go . Good luck. |
| tomeric914 |
Sep 11 2016, 01:28 PM
One Lap of America in a 914! ![]() ![]() ![]() Group: Members Posts: 1,325 Joined: 25-May 08 From: Syracuse, NY Member No.: 9,101 Region Association: North East States
Baldwin B228 is my favorite. Same length as the stock filter but smaller in diameter. Great when using a sandwich adapter for an external cooler or when you're sick of busting your knuckles dealing with the stock size filter.
http://catalog.baldwinfilter.com/PartSpeci...partnumber=B228 |
| TheCabinetmaker |
Sep 11 2016, 02:05 PM
I drive my car everyday ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,378 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
Baldwin B228 is my favorite. Same length as the stock filter but smaller in diameter. Great when using a sandwich adapter for an external cooler or when you're sick of busting your knuckles dealing with the stock size filter. http://catalog.baldwinfilter.com/PartSpeci...partnumber=B228 (IMG:style_emoticons/default/agree.gif) A 944 filter fits too. |
| tomeric914 |
Sep 11 2016, 03:36 PM
Yes, that's a Baldwin B178 which hangs a bit too low on the 914 in my opinion. Same as Rabbit, Jetta, Golf, etc.
http://catalog.baldwinfilter.com/PartSpeci...partnumber=B178 |
Frankvw Oilfilter does not fit Sep 11 2016, 10:10 AM
bretth Is that little wheel a belt tensioner for an AC sy... Sep 11 2016, 10:26 AM
RAX 914 This is the Bosch oil filter I just used:
Sep 11 2016, 10:30 AM
Frankvw Sorry...it is a 1973 1.7 (forgot to mention that)
... Sep 11 2016, 10:41 AM
RAX 914 I have a '72 1.7 and the Bosch 3402 fits well,... Sep 11 2016, 10:53 AM
Mueller
I have a '72 1.7 and the Bosch 3402 fits well... Sep 11 2016, 10:54 AM
Mueller Just buy another smaller diameter filter, it obvio... Sep 11 2016, 10:53 AM
Frankvw Mueller, "it obviously worked since the motor... Sep 11 2016, 11:08 AM
Dave_Darling I would be tempted to get rid of the tensioner. T... Sep 11 2016, 06:01 PM
Big Len I have used the K & N and Mobil 1 filters in a... Sep 11 2016, 06:34 PM
JOEPROPER I would just get another ph195 and call it a day. Sep 11 2016, 07:21 PM
Frankvw Ok...since a PH195 was not available in NL, I boug... Sep 14 2016, 01:02 PM![]() ![]() |
Lo-Fi Version | Time is now: 4th November 2026 - 02:12 PM |
