| JustinMeier |
Sep 12 2016, 12:11 PM
Member ![]() ![]() Group: Members Posts: 244 Joined: 3-August 16 From: Scottsdale Member No.: 20,258 Region Association: None |
There are no tricks ... Remove carpets, pedal board, center console (if installed), center tunnel inspection plate and driver's seat Pop connector at pedal loose and remove ball connector and nut. Disconnect cable from throttle body in engine compartment and push it down thru the engine tin. Crawl under car and pull the sheath loose from the firewall and pull cable out of tube. push new one back thru and secure metal end on stub in firewall. You can push the sheathing back up through the engine tin. Back in the car, fish the throttle cable end out of the center tunnel. Using a mirror, make sure it is not wrapped around the clutch cable. Put the lock nut on threaded end, screw the ball connector on and snap it on the bell crank. Reassemble remainder of interior. Go to engine compartment, secure sheathing to mount, pull cable and secure with barrrel connector to throttle body. Wella ....................... Something like that anyway Anybody want to add anything else or does this pretty much cover it? |
| TheCabinetmaker |
Sep 13 2016, 02:01 PM
I drive my car everyday ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,378 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
Uh, timing cover gaskets? The timing cover is just a threaded plastic plug.
| Toast |
Sep 13 2016, 04:10 PM
Not bad for carrying sway bars. ![]() ![]() ![]() ![]() Group: Members Posts: 3,396 Joined: 20-January 04 From: Las Vegas Member No.: 1,580 Region Association: Southwest Region |
Uh, timing cover gaskets? The timing cover is just a threaded plastic plug. Timing cover....Valve cover. Whatever. (IMG:style_emoticons/default/happy11.gif) He knows what I ment. |
JustinMeier Throttle Cable Replacement **Now In Progress** :) Sep 12 2016, 12:11 PM
ThinAir That's about it. It sounds much more complicat... Sep 12 2016, 12:16 PM
JustinMeier Work just cleaned out the back warehouse so I have... Sep 12 2016, 12:28 PM
Chris914n6 Wouldn't hurt to get a new ball connector, I p... Sep 12 2016, 01:28 PM
JustinMeier
Wouldn't hurt to get a new ball connector, I ... Sep 12 2016, 02:15 PM
Toast :agree:
That ball connector did seem pretty loose... Sep 12 2016, 01:50 PM
Toast The connector in the back that I showed you seemed... Sep 12 2016, 02:43 PM
JustinMeier I went back at lunch and looked a bit more.. Its g... Sep 12 2016, 02:51 PM
Chris914n6 The cable slid easy enough when we had it disconne... Sep 12 2016, 04:21 PM
JustinMeier Bump for edit. Sep 12 2016, 08:26 PM
injunmort how did the cable get anywhere near the exhaust? i... Sep 12 2016, 08:31 PM
Chris914n6 ^^ -6 not 4 Sep 12 2016, 08:48 PM
brant :( Sep 12 2016, 09:04 PM
JustinMeier
Justin. How do the pedals feel when the cable is... Sep 12 2016, 09:20 PM
Toast
We didn't.. I've learned my lesson on thi... Sep 12 2016, 11:39 PM
JustinMeier
Don't beat yourself up Justin. We all learn.... Sep 13 2016, 09:21 AM
injunmort your point being? Sep 12 2016, 09:07 PM
JustinMeier
. Sep 12 2016, 09:56 PM
JustinMeier
Timing cover....Valve cover. Whatever. :evilgri... Sep 13 2016, 08:40 PM
ndfrigi Looks like those cables are the clutch and speedo ... Sep 13 2016, 03:21 PM
JustinMeier
Looks like those cables are the clutch and speedo... Sep 13 2016, 03:35 PM
76-914
Looks like those cables are the clutch and speed... Sep 14 2016, 08:01 AM
Dave_Darling This is a six-cylinder engine, Curt. They may mea... Sep 13 2016, 03:22 PM
JustinMeier Wooohoo.. Cable out and it is most definitely bad.... Sep 13 2016, 09:33 PM
ThinAir
Wooohoo.. Cable out and it is most definitely bad... Sep 13 2016, 09:50 PM
sixnotfour Its a Slits show ... Sep 13 2016, 09:54 PM
JustinMeier
You're going to have ... Sep 13 2016, 10:15 PM
sixnotfour read these 17 pages...
: http://z8.invisionfree.co... Sep 14 2016, 01:34 AM
Kansas 914
: http://z8.invisionfree.c... Sep 14 2016, 07:45 AM
JustinMeier
: http://z8.invisionfree.c... Sep 14 2016, 08:04 AM
Toast
: http://z8.invisionfree.... Sep 15 2016, 06:15 PM
JustinMeier
Well, there is one of the threads for ya. :D
Re... Sep 15 2016, 10:51 PM
JustinMeier One issue.. The new cable doesn't slip around ... Sep 14 2016, 11:51 AM
steuspeed
One issue.. The new cable doesn't slip around... Sep 16 2016, 06:34 PM
JustinMeier
This couldn't have been the problem... Naa... Sep 15 2016, 01:51 PM
JustinMeier So the saga continues... :wttc:
I go to spin th... Sep 15 2016, 11:01 PM
JustinMeier Here's the first whoops...
Sep 15 2016, 11:05 PM
The Cabinetmaker Maybe you should let dad work on his car? Sep 16 2016, 03:30 PM
JustinMeier
:lol:... Sep 16 2016, 06:07 PM
Whitney Mic
Too s... Sep 16 2016, 07:24 PM
porschetub
[quote name='The Cabinetmaker' post='2399346' dat... Sep 18 2016, 12:41 AM
Whitney Mic
I didn't laugh at all thought that was the ... Sep 18 2016, 01:56 AM
JustinMeier I ordered 2 so let's see which one fits..
Ter... Sep 16 2016, 06:50 PM
JustinMeier Thanks for the condolences Whit!
There's ... Sep 16 2016, 09:04 PM
Toast Well I guess that will give you a chance to fix th... Sep 17 2016, 09:01 AM
JustinMeier With some redneck engineering and a drill, I was a... Sep 17 2016, 03:24 PM
The Cabinetmaker Justin, i apologize for being inconsiderate. I ha... Sep 17 2016, 05:48 PM
JustinMeier
Justin, i apologize for being inconsiderate. I h... Sep 17 2016, 06:55 PM
Whitney Mic
Justin, i apologize for being inconsiderate. I h... Sep 17 2016, 10:45 PM
porschetub
Justin, i apologize for being inconsiderate. I h... Sep 18 2016, 01:49 AM
The Cabinetmaker
Justin, i apologize for being inconsiderate. I ... Sep 18 2016, 06:28 AM
N_Jay Evert time I see this thread title in the new post... Sep 17 2016, 09:07 PM
JustinMeier
Well sorta.. this side of the door broke and fe... Sep 18 2016, 12:28 AM
JustinMeier Whoa there. He didn't know so there's a pa... Sep 18 2016, 12:58 AM
76-914 Justin, I feel this is the time and place to say t... Sep 18 2016, 08:08 AM
Toast :agree: Kent
Sometimes there is that one person t... Sep 18 2016, 10:24 AM
JustinMeier :agree: Toast
Thank you Kent! All you guys ar... Sep 18 2016, 10:46 AM
JustinMeier It feels like it's binding at the firewall tub... Sep 18 2016, 10:54 AM![]() ![]() |
Lo-Fi Version | Time is now: 1st November 2026 - 06:10 PM |
