D/L Jetronic fuel pump replacement |
N_Jay |
Sep 13 2016, 07:36 PM
Member Group: Members Posts: 283 Joined: 2-March 16 From: Chicago NW Burbs Member No.: 19,720 Region Association: None |
In the next few weeks I will be putting a (temporary) L-Jetronic 1.8 engine in my 914.
I am not sure I have a working bosch pump, so what is the preferred aftermarket pump these days? Figure with all the EFI cars they should be easy to find, and guessing I will need a regulator to bring the pressure down to the right spec. |
Rob-O |
Sep 14 2016, 08:01 AM
Senior Member Group: Members Posts: 1,252 Joined: 5-December 03 From: Mansfield, TX Member No.: 1,419 Region Association: Southwest Region |
Yup, what Clay said. Works well. The inlet size to the pump is a little large if you're using the factory fuel lines sizes. But it's really easy to rectify the issue. The inlet comes as a brass fitting that screws onto the pump. You cut the barb off that brass fitting, then tap the hole left behind. You then thread a small Ford fuel filter into the tapped hole. It's a brilliant solution, really. The pump is an Airtex E8445 as Clay said. Tap was 1/8-27 NPT. I don't recall the fuel filter (but I bet Clay knows it off the top of his head). I used some self-tapping screws from the local hardware store and mounted the pump on the firewall.
I got all of the parts (pump/filter/tap) at the local O'Reilly's for ~$100. All of it was in stock (pump, filter) or hanging in the tool section (tap). |
Lo-Fi Version | Time is now: 10th June 2024 - 01:59 PM |
