Frankvw |
working on my first 914 ! ![]() ![]() ![]() Group: Members Posts: 652 Joined: 13-April 16 From: Holland, the Netherlands Member No.: 19,896 Region Association: Europe ![]() |
Hi, since I was working to tidy up the engine a bit, check the vacuumhoses, change oil etc, I removed the oilfiller neck, since it is about the dirtiest part in the bay and wanted to clean it.
When I looked in the case with a flashlight to see what it looked like in there, I saw a small plastic cap laying in there. It does fit in the oilfillerneck base bottom, see pic, so I guess that is where it belongs. I took out the Haynes manual but I cannot find this part mentioned. What is it for ? Why is there a capped hole in there ? ![]() |
mark04usa |
'70 1.7 Tangerine ![]() ![]() Group: Members Posts: 351 Joined: 14-September 09 From: Austin TX Member No.: 10,805 Region Association: Southwest Region ![]() ![]() |
Looks like stopper for the breather valve, part # 022 115 486. #9 in diagram
Frankvw |
Looks like stopper for the breather valve, part # 022 115 486. #9 in diagram ![]() Great, that is the one. Thanks ! I will have to check if nothing is missing there... I cannot find it in the Haynes, where did that diagram come from ? From the partnumber you mentioned I found post http://www.914world.com/bbs2/index.php?showtopic=19995 so it happens to others as well :-) What does the valve in there do ? regulation of crankcase pressure ? |
Lo-Fi Version | Time is now: 17th June 2024 - 11:37 AM |
