> Gaskets, Valve cover
cpavlenko
post Sep 14 2016, 05:47 PM
what type gaskets for 1971 1.7, I've heard there tricky to get them in right. Also what type of gasket sealer is recommended?
Frankvw
post Sep 15 2016, 03:07 AM
working on my first 914 !
Region Association: Europe
I can speak from my experience in the VW world (Type1, but also Type4 engines) that I never used any adhesive, sealant or anything like that when installing the cork valvecover gaskets.
When the snapped on coverholder does not have enough tension to keep the cover firm in its spot, it can leak and if the valve cover is warped same thing. If the valvecover is straight and there is enough pressure to hold the cover there should be no need for any product to add.
I know there is a difference in cork-gasket quality, the Original VW ones are really good, so maybe poor quality gaskets can change things to use....
cpavlenko   Gaskets   Sep 14 2016, 05:47 PM
jcd914   I have always used gasgacinch to stick the cork ga...   Sep 14 2016, 06:15 PM
914Sixer   Get some of 914Rubber high temp reusable gaskets a...   Sep 14 2016, 06:24 PM
cpavlenko   Get some of 914Rubber high temp reusable gaskets ...   Sep 14 2016, 06:43 PM
Mikey914   The cork are cheap and stick well. If you use the ...   Sep 14 2016, 07:54 PM
cpavlenko   The cork are cheap and stick well. If you use the...   Sep 14 2016, 08:11 PM
euro911   I recommend the thicker cork gaskets that Mark (91...   Sep 14 2016, 08:40 PM
cpavlenko   I recommend the thicker cork gaskets that Mark (9...   Sep 14 2016, 09:03 PM
euro911   I recommend the thicker cork gaskets that Mark (91...   Sep 14 2016, 09:18 PM
cpavlenko   [quote name='cpavlenko' post='2398534' date='Sep ...   Sep 14 2016, 09:24 PM
JawjaPorsche   I recommend the thicker cork gaskets that Mark (9...   Sep 15 2016, 02:37 AM
Frankvw   I can speak from my experience in the VW world (Ty...   Sep 15 2016, 03:07 AM
Mikey914   I can speak from my experience in the VW world (T...   Sep 15 2016, 10:34 AM
Vacca Rabite   In my experience, if you use a LITTLE smear of RTV...   Sep 15 2016, 09:21 AM
Elliot Cannon   "Elliot is older". And smarter, better...   Sep 15 2016, 12:59 PM
euro911   "Elliot is older". And smarter, better...   Sep 15 2016, 02:17 PM
Elliot Cannon   Read this. http://www.pelicanparts.com/techartic...   Sep 15 2016, 01:04 PM
rhodyguy   I'd be hard pressed to hack up a set of 2.0 ti...   Sep 15 2016, 02:40 PM
cpavlenko   I'd be hard pressed to hack up a set of 2.0 t...   Sep 15 2016, 03:21 PM
Elliot Cannon   I'd be hard pressed to hack up a set of 2.0 t...   Sep 15 2016, 08:48 PM
914_teener   Wait did somebody mention Elliot and silicone........   Sep 15 2016, 09:16 PM
- Lo-Fi Version Time is now: 2nd July 2025 - 01:19 PM
