> Gaskets, Valve cover
cpavlenko
post Sep 14 2016, 05:47 PM
what type gaskets for 1971 1.7, I've heard there tricky to get them in right. Also what type of gasket sealer is recommended?
rhodyguy
post Sep 15 2016, 02:40 PM
I'd be hard pressed to hack up a set of 2.0 tin to provide those vent tubes. Or any set for that matter. Note the carb intake. The cinch-a-gasket works well on the stock cover side. Only! Install the cover with the VW symbol upside down, iirc.
cpavlenko   Gaskets   Sep 14 2016, 05:47 PM
jcd914   I have always used gasgacinch to stick the cork ga...   Sep 14 2016, 06:15 PM
914Sixer   Get some of 914Rubber high temp reusable gaskets a...   Sep 14 2016, 06:24 PM
cpavlenko   Get some of 914Rubber high temp reusable gaskets ...   Sep 14 2016, 06:43 PM
Mikey914   The cork are cheap and stick well. If you use the ...   Sep 14 2016, 07:54 PM
cpavlenko   The cork are cheap and stick well. If you use the...   Sep 14 2016, 08:11 PM
euro911   I recommend the thicker cork gaskets that Mark (91...   Sep 14 2016, 08:40 PM
cpavlenko   I recommend the thicker cork gaskets that Mark (9...   Sep 14 2016, 09:03 PM
euro911   I recommend the thicker cork gaskets that Mark (91...   Sep 14 2016, 09:18 PM
cpavlenko   [quote name='cpavlenko' post='2398534' date='Sep ...   Sep 14 2016, 09:24 PM
JawjaPorsche   I recommend the thicker cork gaskets that Mark (9...   Sep 15 2016, 02:37 AM
Frankvw   I can speak from my experience in the VW world (Ty...   Sep 15 2016, 03:07 AM
Mikey914   I can speak from my experience in the VW world (T...   Sep 15 2016, 10:34 AM
Vacca Rabite   In my experience, if you use a LITTLE smear of RTV...   Sep 15 2016, 09:21 AM
Elliot Cannon   "Elliot is older". And smarter, better...   Sep 15 2016, 12:59 PM
euro911   "Elliot is older". And smarter, better...   Sep 15 2016, 02:17 PM
Elliot Cannon   Read this. http://www.pelicanparts.com/techartic...   Sep 15 2016, 01:04 PM
rhodyguy   I'd be hard pressed to hack up a set of 2.0 ti...   Sep 15 2016, 02:40 PM
cpavlenko   I'd be hard pressed to hack up a set of 2.0 t...   Sep 15 2016, 03:21 PM
Elliot Cannon   I'd be hard pressed to hack up a set of 2.0 t...   Sep 15 2016, 08:48 PM
914_teener   Wait did somebody mention Elliot and silicone........   Sep 15 2016, 09:16 PM
- Lo-Fi Version Time is now: 2nd July 2025 - 12:25 PM
