hard to start, Turning over very slowly |
North Coast Jim |
Sep 15 2016, 10:52 AM
Member Group: Members Posts: 326 Joined: 11-December 15 From: Northern Ohio Member No.: 19,450 Region Association: MidAtlantic Region |
New build just finished. Engine runs and a few items remain to be sorted out such as carb jetting and final timing. Issue is the starter turns over S-L-O-W-L-Y. I'm using the original relay board and jumpered across per a previous posting for ground location, see attachment. Bought and installed the Tangerine Racing carb conversion fuel pump with SS lines and installed it under the steering rack. Ran 12V wiring thru tunnel where the old return line was. I also bought a rebuilt Bosch starter and alternator from Pelican and a new alternator harness for Jeff Bowlsby which included the wiring for the starter. New Hot lead to the starter as well. New battery, a red top Optima. Any guidance on a fix is appreciated. Ignition switch ???? How to fix ??
Attached File(s) Relay_bd_pin_locations.pdf ( 68.78k ) Number of downloads: 31 |
Toast |
Sep 15 2016, 05:23 PM
Not bad for carrying sway bars. Group: Members Posts: 3,377 Joined: 20-January 04 From: Las Vegas Member No.: 1,580 Region Association: Southwest Region |
Lo-Fi Version | Time is now: 10th June 2024 - 01:38 PM |
