FI Wiring Question |
ThinAir |
May 11 2003, 10:12 AM
Best friends Group: Members Posts: 2,543 Joined: 4-February 03 From: Flagstaff, AZ Member No.: 231 Region Association: Southwest Region |
I'm in the last stages of installing an 73 FI 2.0 engine into my 73 that had a carb engine in it. I've got 3 wires coming out of the FI wiring harness near the coil, but don't know for sure where to put them.
A black/red wire and smaller black wire are "bundled" together with a sleeve. From the Haynes wiring diagram it looks like the black/red goes to coil #15. I can't seem to find the black wire on the diagram. There is also a green wire that comes out of the harness by itself (not bundled like the two above). The only green wire on the diagram goes between the coil & the distro so it's obviously the condensor wire, not the one I've got. Can anyone tell me where these wires go? Also, can you confirm that #1 coil is also the one marked + ? I can't see the number markings at the moment and I can never remember which number goes to which +/- sign. Thanks! |
ThinAir |
May 11 2003, 06:07 PM
Wow! I didn't like the looks of the harness that was on the engine (too many butt connectors on wires), so I stole one off one of the engine that came out of my 72. I've got the Oil temp sender for the guage (located in the plate on the bottom of the engine) and it is connected into the main harness via the connector below the battery.
My current symptom is that I've got no spark. Is there any chance that this is because of the ignition harness that I'm using? I figured I probably did something to burn up the Pertronix. I was gonna put a new harness on my Christmas list anyway! |
Lo-Fi Version | Time is now: 11th June 2024 - 12:19 PM |
