> 914/4 rear caliper kits, to use 911 vented rotors
davep
post Jul 10 2004, 06:44 PM
914 Historian
Finally I have the parts for a kit to widen the 914/4 rear caliper for use with 911 vented rear brake rotors.
The kit includes the hub spacers, the caliper spacers and the longer pins.
The kit does not include, at this time, the longer bolts or the extra seals.
I use donor calipers from the 911 rear to provide these bolts and seals.
The bolts in the 914/4 caliper may need a Ribe bit tool to remove.
Reuse the longer (inner) bolts from the caliper to be modified as the shorter (outer) bolts.
These are the parts included in the kit:
davep
post Oct 16 2004, 03:04 PM
914 Historian
The front brakes can be upgraded in many ways. The new hub kits are a great way to start. My preference is to start with a 911S front suspension. That way you have a much greater choice of calipers, rims and torsion bars. My kit compliments a conversion to 5-bolt suspension.
davep   914/4 rear caliper kits   Jul 10 2004, 06:44 PM
davep   This is the modified caliper:   Jul 10 2004, 06:46 PM
davep   These parts are not included at this time, but cou...   Jul 10 2004, 06:48 PM
davep   Differences in the pins:   Jul 10 2004, 06:49 PM
davep   The seals for the spacers:   Jul 10 2004, 06:50 PM
Aaron Cox   cost?   Jul 11 2004, 05:58 PM
datapace   Any update on pricing or availability? -datapace   Aug 10 2004, 07:53 AM
davep   4 kits currently available US$400 plus shippi...   Aug 10 2004, 05:06 PM
dakotaewing   Dave, Could you clarify your pricing? Is the cost ...   Aug 14 2004, 07:56 AM
9146986   Can I just get the spacers and pins? That's a...   Aug 14 2004, 09:06 AM
davep   Clarification: one kit @$400 does two caliper...   Aug 14 2004, 10:01 AM
lylegd   Dave, the special O rings (Porsche calls them Seal...   Aug 19 2004, 09:46 AM
TheAndante   What do you recommend for the fronts? Rears CANNO...   Oct 16 2004, 12:32 PM
davep   The front brakes can be upgraded in many ways. The...   Oct 16 2004, 03:04 PM
McMark   You can use a T27 Torx bit instead of a Ribe, but ...   Oct 16 2004, 07:36 PM
davep   I tried many bit types before finding the correct ...   Oct 17 2004, 07:31 AM
JZH   I installed a similar kit on my 918 many years ago...   Oct 17 2004, 07:15 PM
davep   One kit is available at $300 so that I can he...   Mar 5 2005, 11:04 AM
jonnoshore   For the fronts... This is the route I am going... ...   Apr 13 2005, 03:29 PM
- Lo-Fi Version Time is now: 11th July 2025 - 10:46 AM
