> Bought my 914 need help., Need help
Ncchany
post Oct 1 2016, 12:38 PM
Alright guys i just bought a 914. I am so excited!!! Its a big project so i am going to need your guys help and guidance. Okay for starters the shifter seems loose and the ebrake isnt working? Were do i start with that so i dont have to use chalks
ClayPerrine
post Oct 1 2016, 12:57 PM
I would suggest your first purchase be a Haynes Manual....
(IMG:http://www.914world.com/bbs2/uploads_offsite/ep.yimg.com-1143-1475348271.1.gif)
Haynes Manual
Check the cables on the park brake to make sure they are not frozen. You will also need to check the venting clearance on the rear brake calipers. The Haynes manual has the procedure in it, but the clearance they list is too big. Cut it in half.
If the calipers are good, that should fix the park brake. If the calipers are frozen or leaking, I suggest you contact PMB Performance and get a rebuilt set. You can NEVER be too careful when it comes to the brakes on a car.
As for the shifter, I would need to know the year of the car before I can give you specifics, but check all the bushings in the shift linkage, front to back. Most 914 shifting problems can be fixed with a handful of inexpensive bushings.
Ncchany
post Oct 1 2016, 01:14 PM
Its a 1974 914 1.8l
Also its missing the handbrake lever i think it might have been taken apart. But there is a small white lever i tried pulling it up and it goes up but brakes dont activate
QUOTE(ClayPerrine @ Oct 1 2016, 12:57 PM) *
Haynes Manual
Ncchany   Bought my 914 need help.   Oct 1 2016, 12:38 PM
Ncchany   Alright guys i just bought a 914. I am so excited...   Oct 1 2016, 12:43 PM
zipedadoo   There are cables that runs from the handle to both...   Oct 1 2016, 12:53 PM
ClayPerrine   I would suggest your first purchase be a Haynes Ma...   Oct 1 2016, 12:57 PM
Ncchany   Its a 1974 914 1.8l Also its missing the handbrak...   Oct 1 2016, 01:14 PM
396   I would suggest your first purchase be a Haynes M...   Oct 1 2016, 03:36 PM
ClayPerrine   The handbrake lever should be between the driver...   Oct 1 2016, 01:19 PM
Ncchany   What do you guys think of this? I need help with t...   Oct 1 2016, 01:22 PM
Mblizzard   Plan on replacing allow the shifter bushings. Ins...   Oct 1 2016, 01:28 PM
Shadowfax   :wttc:   Oct 1 2016, 01:59 PM
McMark   Yup, replace all the shifter bushings. All of the...   Oct 1 2016, 03:16 PM
Ncchany   The ebrake is rock solid and wont go up. Where can...   Oct 1 2016, 03:23 PM
Ncchany   The ebrake is rock solid and wont go up. Where ca...   Oct 1 2016, 03:24 PM
cwpeden   [quote name='Ncchany' post='2405743' date='Oct 1 ...   Oct 1 2016, 03:52 PM
Mblizzard   The sources for the bushings are plentiful. But I ...   Oct 1 2016, 03:49 PM
injunmort   as mentioned, remove cable ends from calipers. if ...   Oct 1 2016, 03:56 PM
RobW   :wttc: :wttc: :wttc:   Oct 1 2016, 04:25 PM
Ncchany   :wttc: :wttc: :wttc: Thanks to everyone for...   Oct 1 2016, 05:07 PM
Dave_Darling   Here is some reading material, with photos, about ...   Oct 1 2016, 05:08 PM
euro911   That sure brings back some memories. http://www.9...   Oct 1 2016, 05:25 PM
Ncchany   That sure brings back some memories. http://www....   Oct 1 2016, 06:13 PM
euro911   [quote name='euro911' post='2405811' date='Oct 1 2...   Oct 1 2016, 07:29 PM
rhodyguy   Get and read the book. Do ONE task at a time! ...   Oct 1 2016, 05:48 PM
Ncchany   Get and read the book. Do ONE task at a time...   Oct 1 2016, 06:43 PM
Mikey914   Dude buy the bushings from me and I'll throw ...   Oct 1 2016, 08:40 PM
Ncchany   Dude buy the bushings from me and I'll throw...   Oct 2 2016, 01:23 PM
rhodyguy   What's your take on the most important thing t...   Oct 2 2016, 01:53 PM
McMark   Seek out and eliminate structural rust first. Get ...   Oct 2 2016, 01:55 PM
rhodyguy   If the pass side front is an indication of mark...   Oct 2 2016, 02:00 PM
- Lo-Fi Version Time is now: 12th July 2025 - 04:15 PM
