| Beebo Kanelle |
Sep 30 2016, 04:24 PM
Member ![]() ![]() Group: Members Posts: 248 Joined: 22-November 12 From: Houston, Texas Member No.: 15,177 Region Association: Southwest Region
Need a little wisdom. I installed one of Chris's exhaust systems ( It works beyond a expectations!!!! ) and pulled the push-rod tubes so I could install new Viton O-Rings.
Now, I have two tubes that leak. I watched my trusty Raby Type IV rebuild DVD and first time, straight motor oil. The second time I tried a dab of grease. Both to no avail. These leaks are tiny; just a drop every 3-5 minutes... but one of them is dripping onto the header! Are there any secrets ? mystery goo / sealers to use. Any and all advice is greatly appreciated. |
| r_towle |
Oct 1 2016, 04:12 PM
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States
I know how you feel Elliot but if you use the correct orings you do not need sealant.
Beebo Kanelle Push-Rod Tube Leaks. Sep 30 2016, 04:24 PM
cary I used NAPA/Permatex Thread Sealant w/Teflon #765-... Sep 30 2016, 05:10 PM
The Cabinetmaker +1 on the Teflon thread sealant. Sep 30 2016, 05:44 PM
Elliot Cannon High temp RTV. Works great. Just be careful to c... Sep 30 2016, 06:00 PM
r_towle
High temp RTV. Works great. Just be careful to ... Oct 1 2016, 11:27 AM
mark04usa
As the Cap'n rolls in his grave.
:agree:
... Oct 1 2016, 03:12 PM
rjames
:agree: Oct 1 2016, 03:15 PM
Elliot Cannon
:agree:
... Oct 1 2016, 03:55 PM
injunmort i use hylomar on the seals before installing. yo... Sep 30 2016, 06:27 PM
Beebo Kanelle Thanks to everybody.
I'm on it. Sep 30 2016, 07:07 PM
Krieger I did mine exactly like Elliot's except I used... Sep 30 2016, 11:57 PM
Dave_Darling Clean the bores where the O-rings go thoroughly. ... Oct 1 2016, 12:08 AM
Elliot Cannon
Clean the bores where the O-rings go thoroughly. ... Oct 1 2016, 03:51 PM
914_teener Use the viton seals with the pushrod tubes.
What... Oct 1 2016, 04:37 PM
injunmort i used the victor reinz seals that came in the eng... Oct 1 2016, 04:46 PM
r_towle I am sorry I don't remember the details, but i... Oct 1 2016, 04:47 PM
mark04usa
Buy both types of seals. The green ones fit perfe... Oct 1 2016, 06:09 PM
porschetub
Buy both types of seals. The green ones fit perf... Oct 2 2016, 02:22 AM
mark04usa Regardless of whoever "FAT Performance" ... Oct 2 2016, 01:52 PM
Elliot Cannon I'm sure FAT Performance used the correct seal... Oct 1 2016, 05:45 PM
injunmort ^ and they leaked Oct 1 2016, 06:39 PM
thomasotten This was a great thread - and on the eve of the th... Sep 16 2026, 07:31 AM
Ninja There was a thread on o-rings with an X cross sect... Sep 16 2026, 07:38 AM![]() ![]() |
Lo-Fi Version | Time is now: 16th September 2026 - 09:44 AM |
