| Beebo Kanelle |
Sep 30 2016, 04:24 PM
Member ![]() ![]() Group: Members Posts: 248 Joined: 22-November 12 From: Houston, Texas Member No.: 15,177 Region Association: Southwest Region
Need a little wisdom. I installed one of Chris's exhaust systems ( It works beyond a expectations!!!! ) and pulled the push-rod tubes so I could install new Viton O-Rings.
Now, I have two tubes that leak. I watched my trusty Raby Type IV rebuild DVD and first time, straight motor oil. The second time I tried a dab of grease. Both to no avail. These leaks are tiny; just a drop every 3-5 minutes... but one of them is dripping onto the header! Are there any secrets ? mystery goo / sealers to use. Any and all advice is greatly appreciated. |
| injunmort |
Oct 1 2016, 04:46 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,024 Joined: 12-April 10 From: sugarloaf ny Member No.: 11,604 Region Association: North East States |
i used the victor reinz seals that came in the engine gasket kit. three of the four tubes leaked like sieves. a smear of hylomar on the seals and reassembled, no more leaks. hylomar and permatex red anoerobic sealers dont harden. good enough for rolls royce, good enough for me. i have used viton o rings on '60's era triumph push rod seals, they are not magic and leak just like stock. i am unaware of "the right seals" or where to get them. every type 4 engine i have taken apart, had significant oil leakage around the pushrod tubes. so far about 3000 miles on mine, no leaks. is there any empirical reasons against using sealant aside from personal preference?
Beebo Kanelle Push-Rod Tube Leaks. Sep 30 2016, 04:24 PM
cary I used NAPA/Permatex Thread Sealant w/Teflon #765-... Sep 30 2016, 05:10 PM
The Cabinetmaker +1 on the Teflon thread sealant. Sep 30 2016, 05:44 PM
Elliot Cannon High temp RTV. Works great. Just be careful to c... Sep 30 2016, 06:00 PM
r_towle
High temp RTV. Works great. Just be careful to ... Oct 1 2016, 11:27 AM
mark04usa
As the Cap'n rolls in his grave.
:agree:
... Oct 1 2016, 03:12 PM
rjames
:agree: Oct 1 2016, 03:15 PM
Elliot Cannon
:agree:
... Oct 1 2016, 03:55 PM
injunmort i use hylomar on the seals before installing. yo... Sep 30 2016, 06:27 PM
Beebo Kanelle Thanks to everybody.
I'm on it. Sep 30 2016, 07:07 PM
Krieger I did mine exactly like Elliot's except I used... Sep 30 2016, 11:57 PM
Dave_Darling Clean the bores where the O-rings go thoroughly. ... Oct 1 2016, 12:08 AM
Elliot Cannon
Clean the bores where the O-rings go thoroughly. ... Oct 1 2016, 03:51 PM
r_towle I know how you feel Elliot but if you use the corr... Oct 1 2016, 04:12 PM
914_teener Use the viton seals with the pushrod tubes.
What... Oct 1 2016, 04:37 PM
r_towle I am sorry I don't remember the details, but i... Oct 1 2016, 04:47 PM
mark04usa
Buy both types of seals. The green ones fit perfe... Oct 1 2016, 06:09 PM
porschetub
Buy both types of seals. The green ones fit perf... Oct 2 2016, 02:22 AM
mark04usa Regardless of whoever "FAT Performance" ... Oct 2 2016, 01:52 PM
Elliot Cannon I'm sure FAT Performance used the correct seal... Oct 1 2016, 05:45 PM
injunmort ^ and they leaked Oct 1 2016, 06:39 PM
thomasotten This was a great thread - and on the eve of the th... Sep 16 2026, 07:31 AM
Ninja There was a thread on o-rings with an X cross sect... Sep 16 2026, 07:38 AM![]() ![]() |
Lo-Fi Version | Time is now: 16th September 2026 - 09:44 AM |
