| Beebo Kanelle |
Sep 30 2016, 04:24 PM
Member ![]() ![]() Group: Members Posts: 248 Joined: 22-November 12 From: Houston, Texas Member No.: 15,177 Region Association: Southwest Region
Need a little wisdom. I installed one of Chris's exhaust systems ( It works beyond a expectations!!!! ) and pulled the push-rod tubes so I could install new Viton O-Rings.
Now, I have two tubes that leak. I watched my trusty Raby Type IV rebuild DVD and first time, straight motor oil. The second time I tried a dab of grease. Both to no avail. These leaks are tiny; just a drop every 3-5 minutes... but one of them is dripping onto the header! Are there any secrets ? mystery goo / sealers to use. Any and all advice is greatly appreciated. |
| Elliot Cannon |
Oct 1 2016, 05:45 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Retired Members Posts: 8,487 Joined: 29-December 06 From: Paso Robles Ca. (Central coast) Member No.: 7,407 Region Association: None
I'm sure FAT Performance used the correct seals. This wasn't my idea gentlemen. This was recommended to me. You're right, I'm wrong, can we move on now?
Beebo Kanelle Push-Rod Tube Leaks. Sep 30 2016, 04:24 PM
cary I used NAPA/Permatex Thread Sealant w/Teflon #765-... Sep 30 2016, 05:10 PM
The Cabinetmaker +1 on the Teflon thread sealant. Sep 30 2016, 05:44 PM
Elliot Cannon High temp RTV. Works great. Just be careful to c... Sep 30 2016, 06:00 PM
r_towle
High temp RTV. Works great. Just be careful to ... Oct 1 2016, 11:27 AM
mark04usa
As the Cap'n rolls in his grave.
:agree:
... Oct 1 2016, 03:12 PM
rjames
:agree: Oct 1 2016, 03:15 PM
Elliot Cannon
:agree:
... Oct 1 2016, 03:55 PM
injunmort i use hylomar on the seals before installing. yo... Sep 30 2016, 06:27 PM
Beebo Kanelle Thanks to everybody.
I'm on it. Sep 30 2016, 07:07 PM
Krieger I did mine exactly like Elliot's except I used... Sep 30 2016, 11:57 PM
Dave_Darling Clean the bores where the O-rings go thoroughly. ... Oct 1 2016, 12:08 AM
Elliot Cannon
Clean the bores where the O-rings go thoroughly. ... Oct 1 2016, 03:51 PM
r_towle I know how you feel Elliot but if you use the corr... Oct 1 2016, 04:12 PM
914_teener Use the viton seals with the pushrod tubes.
What... Oct 1 2016, 04:37 PM
injunmort i used the victor reinz seals that came in the eng... Oct 1 2016, 04:46 PM
r_towle I am sorry I don't remember the details, but i... Oct 1 2016, 04:47 PM
mark04usa
Buy both types of seals. The green ones fit perfe... Oct 1 2016, 06:09 PM
porschetub
Buy both types of seals. The green ones fit perf... Oct 2 2016, 02:22 AM
mark04usa Regardless of whoever "FAT Performance" ... Oct 2 2016, 01:52 PM
injunmort ^ and they leaked Oct 1 2016, 06:39 PM
thomasotten This was a great thread - and on the eve of the th... Sep 16 2026, 07:31 AM
Ninja There was a thread on o-rings with an X cross sect... Sep 16 2026, 07:38 AM![]() ![]() |
Lo-Fi Version | Time is now: 16th September 2026 - 09:44 AM |
