| jim_hoyland |
Oct 12 2016, 11:31 AM
Get that VIN ? ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,041 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California
I had the Mahle 94 mm P&C pulled and replaced with 96mms
The pistons were cleaned with oven cleaner; now there are a few black carbon remaining. How should I proceed with removing them before looking for a new home ? Attached image(s)
| rhodyguy |
Oct 12 2016, 12:13 PM
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,252 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
I wouldn't invest a bunch of time cleaning them up if you're going to try to sell them jim. Used engine parts. As is. You'll never see any money for your time.
jim_hoyland Cleaning Pistons Oct 12 2016, 11:31 AM
jim_hoyland Will probley just use the oven cleaner on these to... Oct 12 2016, 11:33 AM
toolguy Be careful, oven cleaner can have lye [sodium hydr... Oct 12 2016, 11:39 AM
StratPlayer Jim http://www.orisonmarketing.com/pistonkleen.... Oct 12 2016, 12:00 PM
echocanyons What is your plan for your build?
Im guessing you ... Oct 12 2016, 12:25 PM
rhodyguy He's moved/moving to a 2056. Oct 12 2016, 12:29 PM
Optimusglen I have a gallon of Berrymans carb/parts cleaner th... Oct 12 2016, 12:59 PM
NeunEinVier
I have a gallon of Berrymans carb/parts cleaner t... Oct 12 2016, 05:56 PM
Mikey914 Tell me that's not from your 1.7. That thing w... Oct 12 2016, 01:20 PM
jim_hoyland I still have an L-Jet; installed new 1.8 heads, 96... Oct 12 2016, 01:38 PM
r_towle See if you can find a drill pad that looks like a ... Oct 12 2016, 04:32 PM
jim_hoyland
See if you can find a drill pad that looks like a... Oct 12 2016, 04:36 PM
jim_hoyland Like this: Oct 12 2016, 06:13 PM
jim_hoyland
Like this:
The guy at O'Reillys said Chen-D... Oct 13 2016, 05:03 PM
Larmo63 Glad you put a bit more giddy-up into your beautif... Oct 13 2016, 05:13 PM
jim_hoyland
Glad you put a bit more giddy-up into your beauti... Oct 14 2016, 06:16 AM
r_towle Chem dip eats aluminum. Oct 14 2016, 04:42 PM
veekry9 VcPkLuX4CAU
Reality check. <_<
https://www... Oct 15 2016, 01:01 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 06:34 PM |
