| Technicolored Horrors |
Oct 18 2016, 08:49 PM
Newbie ![]() Group: Members Posts: 4 Joined: 30-June 13 From: Chicago Member No.: 16,072 Region Association: None |
Hello everyone. I am the proud second owner of a '76 914 2.0. It has been in the custody of my Dad and me since 1987. It is close to mint condition. It has 57,000 original miles. I replaced the goofy gigantic steering wheel and the wheels - other than that it is all original. The paint is near perfect, there is no rust and there are no known mechanical issues.
My first world problem is this: I have always wanted a 6. I want more off-the-line speed. I want that perfect sleeper. Given how few nearly-perfect 914 specimens there are out there, is it dumb/treasonous for me to consider converting my 2.0 to a 6? If it is not, can any of you give me a ballpark of what such a conversion, done correctly, would cost? Thank you for your opinions. |
| McMark |
Oct 18 2016, 09:31 PM
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 20,180 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None |
Cruise up to Grand Rapids before the snow comes and you can take a look at a 3.2 conversion.
The engine is the biggest cost. 3.2 prices have gone up quite a bit. Consider $9000 and if you can get one for less, great. Smaller engines can be had for cheaper, but your savings can quickly evaporate if repairs are necessary. That being said, most 3.2 engines are in need of a top end rebuild now. Oil tank is about $1200 complete. Exhaust is about $700. Engine tin is $1000. Clutch conversion components $600. Motor mount is $400. Muffler is $500. That's about $4500 in conversion parts. Front oil coolers are a good idea, that's around $1500. 6-cylinder tach is on the list too. As far as labor is concerned, you'll need to: -Weld in the motor mount. -Remove the 4-cyl mounts (not necessary, but nice). -Convert the wiring and mount the ECU/DME. -For a 3.2, notch the transmission for the crank trigger sensors. -Adapt the shifter. -Plumb the oil system. -Install the front oil cooler. -Engine maintenance: valve clearances, reseal intake, replace fuel lines, etc. -Adapt the throttle cable/linkage. -Convert the on-engine oil cooler for 914. This is a fairly complete list, but by no means exhaustive. An earlier carbed engine with a documented rebuild can be converted a bit easier (no wiring, no front oil cooler). |
Technicolored Horrors 914 to 914-6: High Treason? Oct 18 2016, 08:49 PM
Larmo63 Probably best to leave it alone, but I'm putti... Oct 18 2016, 08:56 PM
horizontally-opposed To each their own, and the passage of time may mak... Oct 18 2016, 09:05 PM
horizontally-opposed Oh yeah...
:wttc: Oct 18 2016, 09:05 PM
N_Jay
Hello everyone. I am the proud second owner of a... Oct 18 2016, 09:54 PM
Mikey914 Keep your car stock and drive.
Get a second and b... Oct 18 2016, 10:04 PM
OllieG
Get a second and ... Oct 19 2016, 01:28 AM
euro911 [quote name='Mikey914' post='2413014' date='Oct 19... Oct 19 2016, 02:27 AM
Mark Henry
[quote name='Mikey914' post='2413014' date='Oct 1... Oct 19 2016, 07:15 AM
OllieG
[quote name='OllieG' post='2413054' date='Oct 19 ... Oct 19 2016, 09:51 AM
Chris914n6
A mint stock car will be more valuable in the fu... Oct 19 2016, 03:00 PM
JOEPROPER
Get a second and ... Oct 19 2016, 09:26 AM
Larmo63 I'm right in the middle of McMark's disser... Oct 18 2016, 10:14 PM
infraredcalvin This also doesn't include upgraded brakes to s... Oct 18 2016, 10:26 PM
Coondog If you have the money then make the switch...... :... Oct 18 2016, 10:29 PM
Jeff Bowlsby Why bastardize a beautiful original 914/4 with sen... Oct 18 2016, 10:41 PM
malcolm2
Why bastardize a beautiful original 914/4 with se... Oct 19 2016, 05:50 AM
injunmort your car do what you want. having said that. a 2/3... Oct 18 2016, 10:42 PM
Chris914n6 A mint stock car will be more valuable in the futu... Oct 18 2016, 10:56 PM
Catorse
A mint stock car will be more valuable in the fut... Oct 19 2016, 08:52 AM
mepstein Doesn't make sence to date blondes if you real... Oct 19 2016, 04:29 AM
socal1200r
"...Jake Raby charges $20k for his 4 cy... Oct 19 2016, 04:56 AM
mb911 I am not a huge fan of the type 4 mostly because o... Oct 19 2016, 05:09 AM
mb911 I guess my point is you should do it if you want t... Oct 19 2016, 05:10 AM
Cairo94507 I tend to agree your better off to leave your fami... Oct 19 2016, 06:19 AM
Cracker Leave it alone. Buy a second generation Honda S200... Oct 19 2016, 07:07 AM
iwanta914-6 Personally, IF the option to buy another car to mo... Oct 19 2016, 07:36 AM
orthobiz Pictures please. What color?
Paul Oct 19 2016, 07:40 AM
patssle
I'm running stock brakes on 4 lug wheels and... Oct 19 2016, 08:54 AM
Steve If it's a mint unmolested car, I would leave i... Oct 19 2016, 09:03 AM
ConeDodger You should start with the best car you can. So, it... Oct 19 2016, 09:54 AM
PanelBilly Sell it now. Before prices drop more. Buy a comple... Oct 19 2016, 10:10 AM
Cracker Good option but prices have already dropped - you ... Oct 19 2016, 10:35 AM
krazykonrad If its really original, I would stick with stock. ... Oct 19 2016, 10:17 AM
iwanta914-6 Or buy this and save it!
http://www.ebay.com/... Oct 19 2016, 10:20 AM
mb911
http://www.ebay.com... Oct 19 2016, 11:16 AM
malcolm2
[quote name='iwanta914-6' post='2413194' dat... Oct 19 2016, 01:54 PM
sixnotfour I converted my dads 914-4 to a six drove it a long... Oct 19 2016, 11:38 AM
Steve It's from Auto Atlanta, so it's gotta be a... Oct 19 2016, 11:39 AM
Porschef Always seems to be a good deal to be found in that... Oct 19 2016, 11:40 AM
horizontally-opposed A lot of good opinions here, and I respect all of ... Oct 19 2016, 12:06 PM
Ferg
A lot of good opinions here, and I respect all of... Oct 19 2016, 12:13 PM
Amphicar770 Hmm, lots of opinions, guess I will add mine.
For... Oct 19 2016, 12:14 PM
rgalla9146 I'm an old crank I guess.
A beautiful orig... Oct 19 2016, 12:27 PM
altitude411 This has gone on long enough...
:ttiwwp:
* one... Oct 19 2016, 02:36 PM
Rand Simple question: Is this car an investment, or the... Oct 19 2016, 03:21 PM
RickS I converted my near pristine 1971 with 65k miles ... Oct 19 2016, 08:37 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 11:58 AM |
