Trouble with brake bleeding, I can't get any pressure in the system |
Lozgib |
Oct 22 2016, 10:52 AM
Newbie Group: Members Posts: 5 Joined: 29-July 16 From: U.K. Member No.: 20,236 Region Association: None |
Hi. I'm new to Porsche 914 ownership so please go easy on me. I have owned vw splitscreen buses for 30 years and restored loads of them though.
I bought a California 914 a few months back that is running fine now but had been sitting for a number of years needing the brakes restoring as all four callipers had sized and master cylinder leaked. I replaced all four callipers with rebuilt OG units from a reputable USA supplier together with a new master cylinder. I've bled the system 4 times using the easy self pressure method and combined traditional two person method and also combined both together as described on forums. I get clear brake fluid at each wheel with no bubbles but I have no pressure at all at the pedal. It goes straight to the floor. I've read every brake thread on this and other forums and can't find a solution. I have not replaced the pressure regulator as they aren't available her in the uk but would that cause zero pressure? I'm thinking there may be an issue with one or more of the callipers. I've got no leaks I can detect on the system. I'm stumped and lost for what to try next? Any help would be appreciated. |
JPA914 |
Oct 23 2016, 04:13 PM
Member Group: Members Posts: 81 Joined: 30-June 15 From: Houston, TX Member No.: 18,905 Region Association: Southwest Region |
If your bleed nipples are at the bottom of your calipers, that is at least a major part of your problem...period.
Air bubbles rise in a liquid (brake fluid) so you'll never get them out if you don't have a high point in the system from which to purge them. |
mobymutt |
Oct 23 2016, 04:29 PM
Senior Member Group: Members Posts: 550 Joined: 16-December 13 From: Kingston, Ontario, Canada Member No.: 16,770 Region Association: Canada |
If your bleed nipples are at the bottom of your calipers, that is at least a major part of your problem...period. Air bubbles rise in a liquid (brake fluid) so you'll never get them out if you don't have a high point in the system from which to purge them. I agree. Your fronts will still be almost full of air. |
Lo-Fi Version | Time is now: 7th June 2024 - 07:18 PM |
