How to remove axle from rear control arm, Rear Control Arm |
kaiserms |
Oct 28 2016, 09:52 PM
MSKaiser Group: Members Posts: 26 Joined: 8-September 16 From: waterford, michigan Member No.: 20,378 Region Association: Upper MidWest |
[size=6]
I removed the rear swing axles from my '73 914 to replace the bushings & wheel bearing and have powder coated. I have torched out 95% of the old rubber bushings but still can't budge the axle that goes through the center of the control arm. Do I need a stronger torch? Been using small cannister camp stove for torch fuel. Need some clear advice, Thanks, Kaiser |
bdstone914 |
Oct 28 2016, 10:11 PM
bdstone914 Group: Members Posts: 4,543 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
[size=6] I removed the rear swing axles from my '73 914 to replace the bushings & wheel bearing and have powder coated. I have torched out 95% of the old rubber bushings but still can't budge the axle that goes through the center of the control arm. Do I need a stronger torch? Been using small cannister camp stove for torch fuel. Need some clear advice, Thanks, Kaiser Use a shop press of a cheap gear puller from Harbor Freight. Clamp it on the flange. I knocked out 5 of them tonight. Replaced the threaded rod with one about 14" and just drive the pivot shaft out. Added a VW bus nut nut threaded onto the pivot shaft to keep the threaded rod centered on the pivot shaft. It does help to heat the metal until the rubber starts to smoke. If the shaft is badly rusted on the ends it is hard to push them through the rubber bushing. Push it one way a little and it if is bulged with rust grind it down and push it back the other way. Attached thumbnail(s) |
Lo-Fi Version | Time is now: 17th June 2024 - 08:06 AM |
