Can you Change a Tail shifter to a Side Shifter? |
Korijo914 |
Nov 1 2016, 08:06 PM
Newbie Group: Members Posts: 24 Joined: 26-April 16 From: Snohomish WA Member No.: 19,940 Region Association: None |
I have heard that you can change a tail shifter transaxle to a side shifter transaxle. Is this true, or is it just a rumor? If I can change my 5 speed tail shifter transaxle to a 5 speed side shifter transaxle, how do I modify my tail shifter?
If I can, what kind of parts do I need? What kind of preparation is needed to be done? I am assuming that I will need a side shifter transaxle, correct? What else? Oh, I did look all over the site, and found nothing. korijo 914 |
jsaum |
Nov 1 2016, 08:23 PM
Senior Member Group: Members Posts: 530 Joined: 12-June 07 From: Everett, WA Member No.: 7,809 Region Association: None |
Are you asking if you can switch out the transaxle? Yes you can. You can also convert the tail shift case to a side shift. You'll need the side shifter end piece and shifter components along with the shift rods and the engine mount bar. I converted my 72 from the tail shifter to the side shifter with parts from a 75. I just swapped the transaxle.
Jsaum |
Lo-Fi Version | Time is now: 2nd June 2024 - 05:23 AM |
