Korijo914 |
Newbie ![]() Group: Members Posts: 24 Joined: 26-April 16 From: Snohomish WA Member No.: 19,940 Region Association: None ![]() |
I have heard that you can change a tail shifter transaxle to a side shifter transaxle. Is this true, or is it just a rumor? If I can change my 5 speed tail shifter transaxle to a 5 speed side shifter transaxle, how do I modify my tail shifter?
If I can, what kind of parts do I need? What kind of preparation is needed to be done? I am assuming that I will need a side shifter transaxle, correct? What else? Oh, I did look all over the site, and found nothing. korijo 914 |
Dave_Darling |
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 14,991 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California ![]() ![]() |
Hi, Dave! Good to see you around!
The short version: - You need the transmission and the entire shift linkage, even the gear shift lever. Plus the late motor mount bar and the brackets for the bar. And a "converter bushing" for the hole in the firewall. (And possibly the left bottom engine tin piece.) If your tail-shifter is in really good shape, you can actually swap over the shift rails and forks and such from the side-shifter into it, but it's a whole lot easier to just bolt on a side-shifter complete. .... No, wait! I mean, "No you can't do it; it's impossible and nobody has ever done it before!" (IMG:style_emoticons/default/wink.gif) --DD |
Lo-Fi Version | Time is now: 10th June 2024 - 10:35 AM |
