Can you Change a Tail shifter to a Side Shifter? |
Korijo914 |
Nov 1 2016, 08:06 PM
Newbie Group: Members Posts: 24 Joined: 26-April 16 From: Snohomish WA Member No.: 19,940 Region Association: None |
I have heard that you can change a tail shifter transaxle to a side shifter transaxle. Is this true, or is it just a rumor? If I can change my 5 speed tail shifter transaxle to a 5 speed side shifter transaxle, how do I modify my tail shifter?
If I can, what kind of parts do I need? What kind of preparation is needed to be done? I am assuming that I will need a side shifter transaxle, correct? What else? Oh, I did look all over the site, and found nothing. korijo 914 |
euro911 |
Nov 2 2016, 06:32 PM
Retired & living the dream. God help me if I wake up! Group: Members Posts: 8,851 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California |
David, are you sure the 4-speed you have is for a 914? ... was 1st gear deleted for a V8 car or something?
Also, some early 912s came with 4-speed transaxles and they look similar to a tail-shifter - difference being the nose cone and the R&P is different (spins backwards from a 914 trans). But yes, the trans can be built into a 5-speed side shifter. Sounds like you have all the parts necessary to do the trans ... you'll just need the external supporting items as stated above. Post some pix if you can (IMG:style_emoticons/default/confused24.gif) |
Lo-Fi Version | Time is now: 10th June 2024 - 06:54 AM |
