Korijo914 |
Newbie ![]() Group: Members Posts: 24 Joined: 26-April 16 From: Snohomish WA Member No.: 19,940 Region Association: None ![]() |
I have heard that you can change a tail shifter transaxle to a side shifter transaxle. Is this true, or is it just a rumor? If I can change my 5 speed tail shifter transaxle to a 5 speed side shifter transaxle, how do I modify my tail shifter?
If I can, what kind of parts do I need? What kind of preparation is needed to be done? I am assuming that I will need a side shifter transaxle, correct? What else? Oh, I did look all over the site, and found nothing. korijo 914 |
Dave_Darling |
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 14,991 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California ![]() ![]() |
As I said, you can swap over the gear selector stuff from the side-shifter to the tail-shift case. That includes the shift forks and rails. You still use the whole side-shift linkage and side-shift motor mount bar and bracketry.
You don't want to swap the gear stack from the tail-shifter into the side-shift case; the ring and pinion gears should stay with their original case. And changing all of the individual gears out on the stack may result in you having to reset the R&P depth and engagement pattern. Better just to swap the shifting bits from the side-shifter to the tail-shifter trans. --DD |
Lo-Fi Version | Time is now: 10th June 2024 - 11:23 AM |
