915 transmission reverse goes to 4th, 914/915 transmission issue |
colinva914 |
Nov 9 2016, 05:16 PM
Newbie Group: Members Posts: 15 Joined: 7-November 16 From: Ashburn, VA Member No.: 20,567 Region Association: North East States |
Hello,
I have a 915 transmission with side shifter on my 914 ... transmission grinded a couple of times when going to fourth and then a day later when I put the stick in reverse it actually engages 4th gear - anyone see this before? Thanks in advance. -Colin |
Steve |
Nov 9 2016, 05:55 PM
914 Guru Group: Members Posts: 5,614 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
It does sound like your coupler came out of adjustment. Mine is below the center cushion.
Are you using the stock 915 shifter with reverse lockout? I'm using a Rennshift and since reverse is below 5th, when shifting from 5th to 4th, I let the shifter move back to the center plane on its own and then shift down to 4th. It takes a little bit of getting used to, so you don't hit reverse from 5th. Is yours a velios? |
Lo-Fi Version | Time is now: 10th June 2024 - 05:43 AM |
