Stub Hubs, How do you remove them from the trailing arms? |
R_u_dd |
Nov 11 2016, 01:06 AM
Member Group: Members Posts: 154 Joined: 3-March 14 From: Grants Pass, Oregon Member No.: 17,072 Region Association: Pacific Northwest |
I am looking for advice on how to remove the stub Hubs from the trailing arms. There are four 13 mm bolts behind the hub. Is there a special tool to remove them? A socket won't fit and neither will a box wrench. I cut up a socket and welded it to a thin handle and removed one bolt before it broke. Before I destroy more tools I thought I'd ask. Can't find a thread on it. Does the hub push out from the back with a dowel and a mallet? It can't be that difficult...
ClayPerrine |
Nov 11 2016, 07:01 AM
Life's been good to me so far..... Group: Admin Posts: 15,520 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
You have to remove the hubs from the bearing before you can remove the bearing from the trailing arm.
If you have a press, set it up and push the hub out of the bearing. I have a tool that removes the hub while it is in the car, and also removes the bearing after the bolts are out. It can also be done with a BFH (Big F***ING Hammer) and a drift, but it will take time. And it can be painful. Any way you do it, the bearing is scrap. So plan on replacing it. |
Lo-Fi Version | Time is now: 9th June 2024 - 05:13 PM |
