Dip Stick schick, 914-6 Dip Stick questions |
forrestkhaag |
Nov 13 2016, 11:08 AM
Senior Member Group: Members Posts: 935 Joined: 21-April 14 From: Scottsdale, Arizona Member No.: 17,273 Region Association: Southwest Region |
Does anyone know or could anyone show a picture of the correct spot on an original 914-6 dipstick to denote a "full" oil tank. And would a larger motor (than the original) change the place on the dipstick demarking a full oil dose? there is a dot pinched into the stick and three little dotts embossed below that / see pix
thanks (IMG:style_emoticons/default/beerchug.gif) Attached thumbnail(s) |
forrestkhaag |
Nov 13 2016, 06:19 PM
yes / that is the one I have but not so clear as to the line marking the oil level / is that the low level mark mentioned above?
porschetub |
Nov 13 2016, 07:18 PM
Advanced Member Group: Members Posts: 4,706 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
yes / that is the one I have but not so clear as to the line marking the oil level / is that the low level mark mentioned above? Depends what tank you have ,I have proved the marks on the PMS filler/dipstick are useless on a stock tank,maybe ok with their alloy one. I'am running 8 litres of oil with is over the factory level but I have upgrade filter (OC 61 ) and I have larger hoses and lines,that should be more than enough and I only get a 20mm on the PMS dipstick (IMG:style_emoticons/default/dry.gif) ,way below the bottom mark. Thinking maybe the 914rubber one is a better option...don't know |
Lo-Fi Version | Time is now: 10th June 2024 - 01:02 AM |
