Cal |
Senior Member ![]() ![]() ![]() Group: Members Posts: 618 Joined: 19-November 14 From: Philadelphia Member No.: 18,138 Region Association: North East States ![]() |
I'm looking for advice......I'm wrapping up the renovations to my man-cave / shop and will need to heat the space. The area is 650sf in size, constructed with cmu and is uninsulated.....its part of a large 5-car garage / barn structure. I'm not sure if I should go with a propane or electric heater.
Attached thumbnail(s) ![]() |
iankarr |
The wrencher formerly known as Cuddy_K ![]() ![]() ![]() ![]() Group: Members Posts: 2,564 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region ![]() ![]() |
Since NY code requires a dedicated breaker within 6 feet of the unit, I just use that as the "switch".
The thermostat on the unit works well. If I put it on the lowest setting, it only kicks on below 50. |
Kansas 914 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,999 Joined: 1-March 03 From: Durango, Colorado Member No.: 373 Region Association: Rocky Mountains ![]() ![]() |
Since NY code requires a dedicated breaker within 6 feet of the unit, I just use that as the "switch". The thermostat on the unit works well. If I put it on the lowest setting, it only kicks on below 50. Thanks - I have 10' ceilings in the garage and would need a remote switch or use the breaker. |
Lo-Fi Version | Time is now: 9th July 2025 - 04:09 PM |
