> More new stuff - Heat exchanger cover plate gasket Kit, Kit includes both gaskets - 4 new stainless screws $12 now $20 later
Mikey914
post Nov 15 2016, 06:53 PM
The rubber man
This is an "improved" kit that uses a slightly softer high temp silicone to seal the cover plate that joins the blower housing to the sheet metal portion of the heat exchanger on the bottom.
I have included 4 allen head screws with washers. These allow you to get good tension on the screw, and to remove easily without destroying the screw.
I can provide as cork if you prefer at the same cost, but This should be a reusable gasket that is now inexpensive!
Compare to
021256325A
and
021256326A
These go where the sheet metal attaches to the blower. The ones I removed were pitiful. Most are missing completely.
http://shop.914rubber.com/021256325A-02125...m?categoryId=-1
rhodyguy
post Nov 15 2016, 07:00 PM
Nice mark. They used to be cost prohibitive elsewhere.
Mikey914   More new stuff - Heat exchanger cover plate gasket Kit   Nov 15 2016, 06:53 PM
rhodyguy   Nice mark. They used to be cost prohibitive elsewh...   Nov 15 2016, 07:00 PM
BeatNavy   Nice Mark. I'm definitely in for a set. I need...   Nov 15 2016, 07:33 PM
Rob-O   I'll take a set right now. Working on the hea...   Nov 15 2016, 07:41 PM
Mikey914   PMs sent   Nov 16 2016, 12:05 AM
mzalanka   Want. Just got a new set of brackets from bstone...   Nov 16 2016, 12:59 AM
Niklas   3 sets for me.   Nov 16 2016, 01:51 AM
jrblackbox   Put me down for a set, Thanks   Nov 16 2016, 02:05 PM
dlee6204   1set   Nov 16 2016, 02:34 PM
sdthomas   I'll take one set!   Nov 16 2016, 02:39 PM
brownaar   1 set, please!   Nov 16 2016, 04:41 PM
Mikey914   PMs sent to all   Nov 17 2016, 01:28 AM
TX914   I'll take a set. Thanks.   Nov 17 2016, 08:51 AM
porbmw   I'm sure that my daughter's car will need ...   Nov 17 2016, 09:07 AM
pgollender   A set for me too Mikey !   Nov 17 2016, 09:16 AM
ndfrigi   Sir Mike one set for me too.   Nov 17 2016, 10:16 AM
cuddyk   I never even knew those existed! 1 set for me ...   Nov 17 2016, 04:48 PM
Jeff Bowlsby   I'm in for a set of the silicones. Let me kno...   Nov 17 2016, 07:59 PM
914Sixer   I will take a set. Is there an update on the CHT ...   Nov 17 2016, 09:14 PM
rgolia   one set for me.....   Nov 18 2016, 01:54 PM
Mikey914   PMs sent to all - The CHT GB closed, but I If you ...   Nov 18 2016, 01:55 PM
brant   Mark, I need to get a set of these gaskets if th...   Nov 18 2016, 02:04 PM
jesse7flying   I'm in for a set. Sent you a PM, but not sure...   Nov 20 2016, 01:52 PM
smg914   I'll take a set for the creamsicle which is cu...   Nov 20 2016, 02:49 PM
smg914   Can these gaskets be replaced/installed without r...   Nov 27 2016, 04:50 PM
toadman   I would like one set of these seals in silicone, p...   Nov 20 2016, 04:10 PM
Mikey914   PMs sent to all so far.   Nov 21 2016, 01:10 AM
buck toenges   I am a bit confused you have 3 different prices fo...   Nov 21 2016, 12:02 PM
Mikey914   I have 3 different listings one for the 021256325...   Nov 21 2016, 12:10 PM
plas76targa   Mike Please count me in for one "Iimpvved ki...   Nov 21 2016, 06:36 PM
Shadowfax   Please put me down for one also, Mark. Thanks...   Nov 21 2016, 07:03 PM
jim_hoyland   Just saw this today.. I want a set too. BTW: I sh...   Nov 28 2016, 05:56 PM
Mikey914   PjMs sent to all   Nov 28 2016, 11:01 PM
euro911   Mark, I just saw this ... I was in AZ working on t...   Dec 14 2016, 06:54 PM
Marty Yeoman   Mark, Please count me in for a set if still availa...   Dec 14 2016, 11:34 PM
Mikey914   Ok. Merry Christmas Just dropped these on sale on...   Dec 14 2016, 11:46 PM
euro911   Thanks Mark ... I just sent in an order for a bunc...   Dec 15 2016, 01:26 AM
Marty Yeoman   Ordered and PayPal sent. :worship:   Dec 15 2016, 01:52 PM
Mikey914   Left it open til Christmas for those that missed i...   Dec 15 2016, 02:10 PM
barefoot   This is an "improved" kit that uses a s...   Dec 15 2016, 04:35 PM
euro911   ... and the little mouse trap doors that go inside...   Dec 15 2016, 05:42 PM
Mikey914   ... and the little mouse trap doors that go insid...   Dec 15 2016, 06:42 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 02:52 PM
