| Mikey914 |
Nov 15 2016, 06:53 PM
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,772 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None
This is an "improved" kit that uses a slightly softer high temp silicone to seal the cover plate that joins the blower housing to the sheet metal portion of the heat exchanger on the bottom.
I have included 4 allen head screws with washers. These allow you to get good tension on the screw, and to remove easily without destroying the screw. I can provide as cork if you prefer at the same cost, but This should be a reusable gasket that is now inexpensive! Compare to 021256325A and 021256326A These go where the sheet metal attaches to the blower. The ones I removed were pitiful. Most are missing completely. http://shop.914rubber.com/021256325A-02125...m?categoryId=-1 Attached thumbnail(s) |
| Niklas |
Nov 16 2016, 01:51 AM
Porsche 914 Sweden ![]() ![]() Group: Members Posts: 368 Joined: 20-June 09 From: Sweden - Skivarp Member No.: 10,488 Region Association: Scandinavia |
3 sets for me.
Mikey914 More new stuff - Heat exchanger cover plate gasket Kit Nov 15 2016, 06:53 PM
rhodyguy Nice mark. They used to be cost prohibitive elsewh... Nov 15 2016, 07:00 PM
BeatNavy Nice Mark. I'm definitely in for a set. I need... Nov 15 2016, 07:33 PM
Rob-O I'll take a set right now. Working on the hea... Nov 15 2016, 07:41 PM
Mikey914 PMs sent Nov 16 2016, 12:05 AM
mzalanka Want.
Just got a new set of brackets from bstone... Nov 16 2016, 12:59 AM
jrblackbox Put me down for a set, Thanks Nov 16 2016, 02:05 PM
dlee6204 1set Nov 16 2016, 02:34 PM
sdthomas I'll take one set! Nov 16 2016, 02:39 PM
brownaar 1 set, please! Nov 16 2016, 04:41 PM
Mikey914 PMs sent to all Nov 17 2016, 01:28 AM
TX914 I'll take a set. Thanks. Nov 17 2016, 08:51 AM
porbmw I'm sure that my daughter's car will need ... Nov 17 2016, 09:07 AM
pgollender A set for me too Mikey ! Nov 17 2016, 09:16 AM
ndfrigi Sir Mike one set for me too. Nov 17 2016, 10:16 AM
cuddyk I never even knew those existed! 1 set for me ... Nov 17 2016, 04:48 PM
Jeff Bowlsby I'm in for a set of the silicones. Let me kno... Nov 17 2016, 07:59 PM
914Sixer I will take a set. Is there an update on the CHT ... Nov 17 2016, 09:14 PM
rgolia one set for me..... Nov 18 2016, 01:54 PM
Mikey914 PMs sent to all -
The CHT GB closed, but I
If you ... Nov 18 2016, 01:55 PM
brant Mark,
I need to get a set of these gaskets if th... Nov 18 2016, 02:04 PM
jesse7flying I'm in for a set. Sent you a PM, but not sure... Nov 20 2016, 01:52 PM
smg914 I'll take a set for the creamsicle which is cu... Nov 20 2016, 02:49 PM
smg914
Can these gaskets be replaced/installed without r... Nov 27 2016, 04:50 PM
toadman I would like one set of these seals in silicone, p... Nov 20 2016, 04:10 PM
Mikey914 PMs sent to all so far. Nov 21 2016, 01:10 AM
buck toenges I am a bit confused you have 3 different prices fo... Nov 21 2016, 12:02 PM
Mikey914 I have 3 different listings
one for the 021256325... Nov 21 2016, 12:10 PM
plas76targa Mike
Please count me in for one "Iimpvved ki... Nov 21 2016, 06:36 PM
Shadowfax Please put me down for one also, Mark. Thanks... Nov 21 2016, 07:03 PM
jim_hoyland Just saw this today.. I want a set too.
BTW: I sh... Nov 28 2016, 05:56 PM
Mikey914 PjMs sent to all Nov 28 2016, 11:01 PM
euro911 Mark, I just saw this ... I was in AZ working on t... Dec 14 2016, 06:54 PM
Marty Yeoman Mark,
Please count me in for a set if still availa... Dec 14 2016, 11:34 PM
Mikey914 Ok. Merry Christmas
Just dropped these on sale on... Dec 14 2016, 11:46 PM
euro911 Thanks Mark ... I just sent in an order for a bunc... Dec 15 2016, 01:26 AM
Marty Yeoman Ordered and PayPal sent. :worship: Dec 15 2016, 01:52 PM
Mikey914 Left it open til Christmas for those that missed i... Dec 15 2016, 02:10 PM
barefoot
This is an "improved" kit that uses a s... Dec 15 2016, 04:35 PM
euro911 ... and the little mouse trap doors that go inside... Dec 15 2016, 05:42 PM
Mikey914
... and the little mouse trap doors that go insid... Dec 15 2016, 06:42 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 04:11 PM |
