> Upper Dash Face replacement
Speedmster
post Nov 19 2016, 08:12 AM
We have been freshing up dads 914-6 (#1006). Had some paint work done and several other touch ups here and there.
We have the windshield out because the seal was dried up and only sealing 2/3rds the way around. With the windshield out we decided to replace the cracked dash pad and to replace the upper dash face (I think that is what it is called). My question is can the upper dash face be replaced with the windshield out without dropping the dash itself? If so, how do you recommend getting the forward edge of the material around and under the lip?
Clint
(IMG:http://www.914world.com/bbs2/uploads_offsite/i9.photobucket.com-8132-1479564773.1.jpg)
(IMG:http://www.914world.com/bbs2/uploads_offsite/i9.photobucket.com-8132-1479564773.2.jpg)
(IMG:http://www.914world.com/bbs2/uploads_offsite/i9.photobucket.com-8132-1479564774.3.jpg)
(IMG:http://www.914world.com/bbs2/uploads_offsite/i9.photobucket.com-8132-1479564774.4.jpg)
iankarr
post Nov 19 2016, 08:48 AM
Very cool that you're doing that for your dad. Yes, you can install the top pad with the dash in the car, but the job is so much easier and will turn out better if you remove the dash frame. You'll also be glad you did when it comes time to install the new main dash pad and you don't break your knuckles trying to get at the two studs behind the instrument cluster. IMHO the time you spend struggling to get everything smooth and stick properly (so that the edges don't start peeling up in the summer) will be equal to or greater than what it will take to remove the dash frame and do the job right. Totally worth it while the glass is out! Especially on a -6.
I just did this project. Pm me if you have any questions!
Speedmster
post Nov 19 2016, 09:32 AM
QUOTE(cuddyk @ Nov 19 2016, 09:48 AM) *
Most of the dash is apart thanks to getting to the dash pad nuts (IMG:style_emoticons/default/chair.gif) . So if my thought process is right, the blower switch, instrument panel, and steering column will need to be removed or least disconnected correct? Is there anything different for a -6 with the steering column that will need to be done?
I've been referencing a thread from the Lapuwali Classic Thread Forum, but it is from a -4
http://www.914world.com/bbs2/index.php?showtopic=42757
Clint
iankarr
post Nov 19 2016, 09:43 AM
QUOTE(Speedmster @ Nov 19 2016, 10:32 AM) *
Clint
Hey Clint... That classic thread is great. Pictures help a lot. And I'm sure I forgot something that's covered there (IMG:style_emoticons/default/wink.gif). I only have a -4, so I'm not sure if there are other quirks which make removal different, but there shouldn't be. Yes, you'll need to remove the instrument cluster and steering "collar". This is a great time to have Tim refresh your gauges and update to LED. Or you can follow his thread to do it yourself...
http://www.914world.com/bbs2/index.php?showtopic=217100
Speedmster   Upper Dash Face replacement   Nov 19 2016, 08:12 AM
tygaboy   Sorry, I'm no help on the dash pad but I have ...   Nov 19 2016, 08:25 AM
cuddyk   Very cool that you're doing that for your dad....   Nov 19 2016, 08:48 AM
Speedmster   Very cool that you're doing that for your dad...   Nov 19 2016, 09:32 AM
cuddyk   [quote name='cuddyk' post='2424783' date='Nov 19 ...   Nov 19 2016, 09:43 AM
stevegm   :popcorn: I am getting ready to do the exact sam...   Nov 19 2016, 08:56 AM
toolguy   Keep life simple, leave the glass out until you h...   Nov 19 2016, 09:13 AM
Speedmster   Keep life simple, leave the glass out until you ...   Nov 19 2016, 09:17 AM
cuddyk   Go for it! Here's a summary of how to remo...   Nov 19 2016, 09:34 AM
boxstr   The one thing I found that I used a foam under the...   Nov 19 2016, 01:29 PM
rgalla9146   The one thing I found that I used a foam under th...   Nov 19 2016, 04:45 PM
Speedmster   The one thing I found that I used a foam under th...   Nov 19 2016, 06:15 PM
Speedmster   Double Post   Nov 19 2016, 06:16 PM
Mikey914   You can use 1/8" headliner material.   Nov 20 2016, 03:12 AM
Speedmster   We got the dash out and much to our surprise the c...   Mar 12 2017, 06:06 PM
Speedmster   repop   Mar 12 2017, 06:08 PM
Speedmster   mor follow on   Mar 12 2017, 06:09 PM
Speedmster   RE: Upper Dash Face replacement   Mar 12 2017, 06:10 PM
Speedmster   repop   Mar 12 2017, 06:12 PM
Speedmster   Any ideas why the numbers hand written below dash ...   Mar 12 2017, 06:15 PM
mepstein   Maybe since Porsche assembled the car, not Karman....   Mar 12 2017, 07:57 PM
Speedmster   Maybe since Porsche assembled the car, not Karman...   Mar 13 2017, 02:21 AM
mepstein   Maybe since Porsche assembled the car, not Karma...   Mar 13 2017, 05:27 AM
Frankvw   I think that is more common than you would think. ...   Mar 12 2017, 11:44 PM
davep   Sorry that I did not see this years ago. The numbe...   Jan 23 2025, 03:28 PM
- Lo-Fi Version Time is now: 26th October 2026 - 06:46 PM
