| tazz9924 |
Nov 19 2016, 04:33 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 755 Joined: 31-May 15 From: Mooresville NC Member No.: 18,779 Region Association: None |
Ok, So, i have an ej205 in my car and until recently ive had just a hose going from one end of the heater pipes to the other. But lately i got the big idea to move to the 20th century and so i added a heater core up front. this meant ~ 20' of 5/8" heater hose (autozone was just thrilled) filled the hoses with water added a bleeder and BAM heat......Or so i thought. My car ran consistently 170-180 now at idle im around 207-208 and it climbs to 230 before im too scared to drive more. ive been attempting to bleed it for three days scolding myself all along they way. What have i done wrong or what can i try, ive been on hills stopped suddenly and swerved hardcore. is it possible that now my car just runs hotter or is there a magic trick for removing air please help!
| zipedadoo |
Nov 20 2016, 08:55 AM
Member ![]() ![]() Group: Members Posts: 135 Joined: 23-January 14 From: Arizona Member No.: 16,921 Region Association: None |
That looks like the same way I ran my heater.
If you close that shutoff valve it will cause the car to over heat. On a Subaru the collant has to keep flowing in the heater curicut. I read that some where online and I know my car will run hot if I shut the water off to the heater core. Something about the thermostat not working right if that flow is shut off. Apparently we need to use a 4 way heater valve. It will shut off all collant to the heater core yet still keep the coolant flowing on the engine side. My enginge is a ej22 and I'm not sure if thay are all the same in this regard. To help get rid of any air in the sytem I am able to fill the system through the "bleeder" near the heater core. I used one of those coolant flush tees with a removable cap and fabricated a funnel to screw on to it. |
| tazz9924 |
Nov 20 2016, 11:26 AM
That looks like the same way I ran my heater. To help get rid of any air in the sytem I am able to fill the system through the "bleeder" near the heater core. I used one of those coolant flush tees with a removable cap and fabricated a funnel to screw on to it. Ive done that with a normal funnel and jesus christ! when the hot water gets to it it starts mixing with the cold water bubbling and popping and over filling the funnel then if i remove the funnel a jet of 200' steam shoots me in the face its mad!..... maybe i should try when its cold. thx for the info on the 4 way valve though (IMG:style_emoticons/default/beerchug.gif) |
tazz9924 Cooling problems in the winter. Nov 19 2016, 04:33 PM
matthepcat I suggest adding some pictures of your system. Har... Nov 19 2016, 05:13 PM
tazz9924 sorry for the crappy photo. then the heater core i... Nov 19 2016, 05:57 PM
Andyrew Betcha its air. Nov 19 2016, 06:00 PM
matthepcat ^^ I agree ^^
You're introducing more tubing... Nov 19 2016, 06:17 PM
tazz9924
^^ I agree ^^
You're introducing more tubin... Nov 19 2016, 07:40 PM
zipedadoo Make sure your heater core and hoses are not block... Nov 19 2016, 07:09 PM
914_teener
Make sure your heater core and hoses are not bloc... Nov 19 2016, 07:44 PM
tazz9924 so its basically this
Nov 20 2016, 12:09 AM
matthepcat What ports are you pulling hot water off the engin... Nov 20 2016, 03:12 AM
zipedadoo My funnel/bleeder set up. This way I get a real hi... Nov 20 2016, 09:05 AM
tazz9924 where can i get a 4 way valve? all my hoses r 5/8
... Nov 20 2016, 11:29 AM
zipedadoo I found the 4 way valve on Amazon. They sell a cab... Nov 20 2016, 04:56 PM
76-914 You need one of these:
the other side:
and y... Nov 20 2016, 05:39 PM
tazz9924 I removed the heater because i couldn't bleed ... Dec 2 2016, 05:53 PM
rhodyguy Have you bought the parts that were suggested? You... Dec 2 2016, 06:52 PM
tazz9924
Have you bought the parts that were suggested? Yo... Dec 2 2016, 07:46 PM
76-914 Take a pic of your hose routing in the engine bay.... Dec 2 2016, 07:20 PM
tazz9924
Take a pic of your hose routing in the engine bay... Dec 2 2016, 07:49 PM
76-914 If nothings changed then I'd verify the temp y... Dec 3 2016, 08:57 AM
tazz9924
If nothings changed then I'd verify the temp ... Dec 3 2016, 02:17 PM
tazz9924 Ok so the hoses r nothing special the go from the ... Dec 3 2016, 03:28 PM
tazz9924 more pics Dec 3 2016, 03:29 PM
904svo Due to the way Subaru operates the thermostat it m... Dec 3 2016, 04:14 PM
tazz9924
Due to the way Subaru operates the thermostat it ... Dec 3 2016, 06:31 PM
76-914
Due to the way Subaru operates the thermostat it... Dec 3 2016, 07:33 PM
tazz9924
[quote name='tazz9924' post='2430031' date='Dec 3... Dec 3 2016, 10:44 PM
xmotox hey taz i live in lakewood and would like to sea y... Dec 4 2016, 12:55 AM
76-914 Take him up on that offer Tazz. Two head are bette... Dec 4 2016, 08:57 AM![]() ![]() |
Lo-Fi Version | Time is now: 8th July 2026 - 03:29 AM |
