| vintage914racer |
Nov 21 2016, 10:58 PM
Member ![]() ![]() Group: Members Posts: 464 Joined: 28-December 03 From: Minneapolis, MN Member No.: 1,473 |
Long story short, a couple of years ago I had premature engine failure on my 914-6 track car. If you're bored you can check out part 1 and part 2 of my engine misadventure. Otherwise, I'll continue on the the regular scheduled dash programming...
We all know how the slippery slope works and before you knew it I had the car apart in hundreds of pieces tackling various "cheaper" projects while amassing engine parts and waiting for the engine builder. One of the projects I wanted to tackle for years was a dash rebuild. You see this car has been a track car since 1972 and judging by the great number of patches to the existing dash I wouldn't be surprised if it was original to the track car build. ![]() At any rate the dash was riddled wtih holes, a complete rats nest of wires and a melange of various metallic and composite (fancy word for cheap plastic) finishes. My goal was to set about cleaning up the aesthetic, going a bit modern on the gauge front and clean up the wiring with a new fused junction box. And so it began... The first step was making a trip to the local metal supplier. Now, if you're in Minneapolis you shoudl check out Discount Steel. As a complete metal shopping newb I was a little apprehensive, but upon arrival the folks were friendly, overwhelmingly helpful and generally a good lot. Armed with a couple strips of aluminum sheet I headed home. ![]() I proceeded to trace my old dash panel with a Sharpie and cut out a new panel. After some trimming, fitting, trimming, fitting, trimming and re-fitting I settled on a fit that I was happy with. If you're wondering why all the trimming let's just say I'm a measure 12 times and still cut wrong kind of guy. ![]() After a bit of drilling I had the panel mocked up and in place. Satisfied with the fit I moved on to the next step... |
| vintage914racer |
Nov 21 2016, 11:24 PM
As the dash slowly started to take form I couldn't help but mock it up on my workbench. Consider it a glimpse at what was to come and a small light the end of the tunnel.
![]() In the photo above you can see the new fuse block I was integrating. I ended up going with a Blue Sea Systems Blade Fuse Block that I picked up from the West Marine next to my office. We used the same block in our Chumpcar with good result. ![]() I proceeded to install the main panel and make sure everything was placed properly. Once I felt good about the arrangement I upholstered the gauge pod. In the photo below you can kind of see one of the access panels I fabbed up. ![]() A bit more spray adhesive and "recycled" binder clips and the pod was all set. I don't have pictures, but I also upholstered the top access panel. ![]() From here it was assembly and wiring time... Attached image(s)
vintage914racer My Track Dash Reconstruction Nov 21 2016, 10:58 PM
vintage914racer The next step was to build a gauge pod that tiled ... Nov 21 2016, 11:16 PM
vintage914racer In my head there were two things working against m... Nov 21 2016, 11:39 PM
vintage914racer So, to make a long story a little less long, I com... Nov 21 2016, 11:42 PM
carcus Great work!!! Looks awesome!!... Nov 22 2016, 02:24 AM
vintage914racer
Great work!!! Looks awesome!... Nov 22 2016, 06:55 AM
mgp4591 What a cool upgrade, making the car look better an... Nov 22 2016, 02:32 AM
RobW :agree:
Nice job! There's nothing more s... Nov 22 2016, 07:00 AM
jmitro very nice job! great work Nov 22 2016, 07:03 AM
Frankvw Great update ! And kudos to the craftmaster wi... Nov 22 2016, 07:07 AM
vintage914racer
Great update ! And kudos to the craftmaster w... Nov 22 2016, 07:23 AM
tygaboy Another great example of getting in there and just... Nov 22 2016, 07:54 AM
vintage914racer
Another great example of getting in there and jus... Nov 22 2016, 05:23 PM
whitetwinturbo :headbanger: :headbanger: :headbanger: ............ Nov 23 2016, 11:14 PM
gms Ben, It looks very nice! Nov 25 2016, 10:26 AM![]() ![]() |
Lo-Fi Version | Time is now: 23rd November 2026 - 01:33 AM |
