| vintage914racer |
Nov 21 2016, 10:58 PM
Member ![]() ![]() Group: Members Posts: 464 Joined: 28-December 03 From: Minneapolis, MN Member No.: 1,473 |
Long story short, a couple of years ago I had premature engine failure on my 914-6 track car. If you're bored you can check out part 1 and part 2 of my engine misadventure. Otherwise, I'll continue on the the regular scheduled dash programming...
We all know how the slippery slope works and before you knew it I had the car apart in hundreds of pieces tackling various "cheaper" projects while amassing engine parts and waiting for the engine builder. One of the projects I wanted to tackle for years was a dash rebuild. You see this car has been a track car since 1972 and judging by the great number of patches to the existing dash I wouldn't be surprised if it was original to the track car build. ![]() At any rate the dash was riddled wtih holes, a complete rats nest of wires and a melange of various metallic and composite (fancy word for cheap plastic) finishes. My goal was to set about cleaning up the aesthetic, going a bit modern on the gauge front and clean up the wiring with a new fused junction box. And so it began... The first step was making a trip to the local metal supplier. Now, if you're in Minneapolis you shoudl check out Discount Steel. As a complete metal shopping newb I was a little apprehensive, but upon arrival the folks were friendly, overwhelmingly helpful and generally a good lot. Armed with a couple strips of aluminum sheet I headed home. ![]() I proceeded to trace my old dash panel with a Sharpie and cut out a new panel. After some trimming, fitting, trimming, fitting, trimming and re-fitting I settled on a fit that I was happy with. If you're wondering why all the trimming let's just say I'm a measure 12 times and still cut wrong kind of guy. ![]() After a bit of drilling I had the panel mocked up and in place. Satisfied with the fit I moved on to the next step... |
| vintage914racer |
Nov 21 2016, 11:42 PM
So, to make a long story a little less long, I completed the dash. I have to say that I'm pretty happy with it. The Traqdash worked pretty flawlessly. Other than having the old pressure leads connected backwards and popping fuse that was too small for the fuel pump everything worked as expected. I've included a couple "close to completed" dash pictures below. I'll post current photos shortly.
![]() I did repace the cheapie voltmeter with a matching VDO gauge. The old one is still in the picture below. ![]() |
vintage914racer My Track Dash Reconstruction Nov 21 2016, 10:58 PM
vintage914racer The next step was to build a gauge pod that tiled ... Nov 21 2016, 11:16 PM
vintage914racer As the dash slowly started to take form I couldn... Nov 21 2016, 11:24 PM
vintage914racer In my head there were two things working against m... Nov 21 2016, 11:39 PM
carcus Great work!!! Looks awesome!!... Nov 22 2016, 02:24 AM
vintage914racer
Great work!!! Looks awesome!... Nov 22 2016, 06:55 AM
mgp4591 What a cool upgrade, making the car look better an... Nov 22 2016, 02:32 AM
RobW :agree:
Nice job! There's nothing more s... Nov 22 2016, 07:00 AM
jmitro very nice job! great work Nov 22 2016, 07:03 AM
Frankvw Great update ! And kudos to the craftmaster wi... Nov 22 2016, 07:07 AM
vintage914racer
Great update ! And kudos to the craftmaster w... Nov 22 2016, 07:23 AM
tygaboy Another great example of getting in there and just... Nov 22 2016, 07:54 AM
vintage914racer
Another great example of getting in there and jus... Nov 22 2016, 05:23 PM
whitetwinturbo :headbanger: :headbanger: :headbanger: ............ Nov 23 2016, 11:14 PM
gms Ben, It looks very nice! Nov 25 2016, 10:26 AM![]() ![]() |
Lo-Fi Version | Time is now: 23rd November 2026 - 01:33 AM |
