| Gunn1 |
Nov 24 2016, 10:18 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,021 Joined: 14-February 16 From: Minnesota Member No.: 19,670 Region Association: None |
I looked back (did a search) trying to locate a ready made set up that would replace the old clutch cable stuff and replace it with a Hydraulic/slave cylinder configuration. I found a few photos and a few posts saying there would be a kit forthcoming, but up to this point I haven't come across it. (IMG:style_emoticons/default/confused24.gif) Also saw a "hydraulically" actuated throw-out bearing. (IMG:style_emoticons/default/confused24.gif) This would be for a stock 75' 2 liter and tranny.
Also want to keep the pedal locations stock (I'm tall) the car also has the front and rear sway bars. Even more importantly does anyone have experience with either set up. Any thoughts or pointers in the right direction would be great. |
| jmill |
Nov 25 2016, 12:42 PM
Green Hornet ![]() ![]() ![]() ![]() Group: Members Posts: 2,449 Joined: 9-May 08 From: Racine, Wisconsin Member No.: 9,038 Region Association: Upper MidWest |
The auto stick bugs did it with vacuum. There was a switch in the stick shift handle that actuated clutch when you pressed down and also when you pressed brake.
Gunn1 clutch slave Nov 24 2016, 10:18 AM
GeorgeRud Don't think anyone offers a bolt-in kit, thoug... Nov 24 2016, 09:34 PM
porschetub I just don't see the point unless you have V8 ... Nov 25 2016, 12:14 AM
mb911 I desperately need something like this for dad... Nov 25 2016, 11:34 AM
mgp4591
I desperately need something like this for dad... Nov 25 2016, 04:35 PM
mb911
I desperately need something like this for dad... Nov 25 2016, 05:01 PM
porschetub Fair enough , sorry didn't know of your needs. Nov 25 2016, 12:26 PM
shoguneagle The hydraulic clutch was done years ago by "a... Nov 25 2016, 01:11 PM
Mikey914 Look at the 944 / 951 this is a stock set up. May ... Nov 25 2016, 01:16 PM
Gunn1
Look at the 944 / 951 this is a stock set up. May... Nov 25 2016, 02:05 PM
amfab this place is awesome Nov 25 2016, 03:15 PM
Gunn1
The awesomest Nov 25 2016, 03:45 PM
Mikey914 With the hydraulic the piston size is close to 1/1... Nov 25 2016, 04:46 PM
Mark Henry Someone else did it with VW vanagon parts.
Hard p... Nov 25 2016, 05:49 PM![]() ![]() |
Lo-Fi Version | Time is now: 7th December 2025 - 09:01 PM |
