> Troble with wrench fit, On front calipers
PanelBilly
post Nov 27 2016, 01:36 PM
Its time to bleed my brakes and freshen up the fluid. Back calipers are easy, but fronts are a pain. I'm using the self bleeding screws and there isn't enough room to get a box wrench around the screw. The open end is too tight to fit securely too. I'm looking for a thin 8mm box wrench but all I find is thin open ends. What are the rest of you using?
McMark Edit: caliber -> caliper
Elliot Cannon
post Nov 27 2016, 01:39 PM
Group: Retired Members
QUOTE(PanelBilly @ Nov 27 2016, 11:36 AM) *
Its time to bleed my brakes and freshen up the fluid. Back calibers are easy, but fronts are a pain. I'm using the self bleeding screws and there isn't enough room to get a box wrench around the screw. The open end is too tight to fit securely too. I'm looking for a thin 8mm box wrench but all I find is thin open ends. What are the rest of you using?
Buy a cheap wrench and grind it down to fit.
- Lo-Fi Version Time is now: 30th April 2026 - 12:19 AM
