| PanelBilly |
Nov 27 2016, 01:36 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,958 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest
Its time to bleed my brakes and freshen up the fluid. Back calipers are easy, but fronts are a pain. I'm using the self bleeding screws and there isn't enough room to get a box wrench around the screw. The open end is too tight to fit securely too. I'm looking for a thin 8mm box wrench but all I find is thin open ends. What are the rest of you using?
McMark Edit: caliber -> caliper |
| 914Sixer |
Nov 27 2016, 06:57 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,470 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region
Are you SURE someone did not switch bleeders with SAE fittings? Try a good ole American size next.
PanelBilly Troble with wrench fit Nov 27 2016, 01:36 PM
Elliot Cannon
Its time to bleed my brakes and freshen up the fl... Nov 27 2016, 01:39 PM
messix find one of these http://www.parktool.com/product/... Nov 27 2016, 01:42 PM
11tenths I always try to break the bleeders free with a dee... Nov 27 2016, 01:51 PM
cary Second on 6 pt. no matter which tool you choose.
... Nov 27 2016, 04:42 PM
PanelBilly the issue isn't the fit of the screw but it... Nov 28 2016, 12:10 PM
McMark
the issue isn't the fit of the screw but it... Nov 28 2016, 01:35 PM
rjames I don't remember having any issues getting a c... Nov 28 2016, 01:13 PM
wndsnd Second on ignition wrenches Nov 28 2016, 01:16 PM
sixnotfour flare nut wrench is way to beefy, just get a brake... Nov 28 2016, 02:26 PM
whitetwinturbo :popcorn: :popcorn: :popcorn: Nov 28 2016, 11:10 PM
Jeff Bowlsby Seems to me the speedbleeders are 8mm. I use them... Nov 28 2016, 11:37 PM![]() ![]() |
Lo-Fi Version | Time is now: 30th April 2026 - 12:19 AM |
