| Mowog4 |
Nov 28 2016, 02:02 PM
Member ![]() ![]() Group: Members Posts: 361 Joined: 2-November 15 From: Mesa AZ Member No.: 19,325 Region Association: None
I am looking for input on wiring a pair of heated seats. They draw about 5 amps each. Any suggestions on where I should run the power from.
| jim_hoyland |
Nov 28 2016, 03:34 PM
Get that VIN ? ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,033 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California
I installed heated seats about 10 years ago; works great !
I wired mine to the rear window defrost circuit and used a dash switch to turn the circuit on. 1. Dash; old fog light switch with switched power source; run the other lead to the front of the relay board. I ran mine down the tunnel , then behind the seat and through a hole just in front of the relay board. 2. Seat: Two wires; one is a ground, the other wire goes up to the front of the relay board next to the wire from the dash. 3. In the front of the relay board are two posts and a position holder ( like the fuel tank sender ). Those two posst connect to the rear window defrost relay-the first relay from the front. 4. The wire from the dash goes on one of those posts. It is the trigger wire ( aka 85) for the relay. 5. The other post is the relays 87 or 12v output. 6. Its that simple. Relay already has power and is wired for a similar application. You are just going to use it for seat heaters instead of the heated window 7. And, my voltmeter doesn't even move when the heaters are on- and I have my voltmeter wired directly to the battery. 8. I was lucky in that I found a rear window defrost connector that fits directly onto the two posts. Good luck, and enjoy ! I use mine almost every day in the am or if I have a ore back... (IMG:style_emoticons/default/smile.gif) |
Mowog4 Adding Heated Seats Nov 28 2016, 02:02 PM
McMark Fuses 10/11/12 are all battery direct, I would use... Nov 28 2016, 02:32 PM
Mowog4 Mark
For those of us who strive to do a more profe... Nov 28 2016, 08:59 PM
McMark For those of us who strive to do a more profession... Nov 29 2016, 07:57 AM
Elliot Cannon
Mark
For those of us who strive to do a more prof... Nov 29 2016, 07:03 PM
McMark Oh, duh. Thinking about Jim's post reminded m... Nov 28 2016, 04:15 PM
76-914 I ran a 12ga dedicated circuit from a battery dist... Nov 28 2016, 05:37 PM
Mowog4 Thanks for the tips, even though I am in the deser... Nov 28 2016, 07:21 PM
whitetwinturbo :popcorn: .........and where is the link(s) to do ... Nov 28 2016, 11:34 PM
:popcorn: .........and where is the link(s) to do... Nov 29 2016, 05:17 AM
Mikey914
:popcorn: .........and where is the link(s) to do... Nov 29 2016, 10:59 AM
Philip W.
:popcorn: .........and where is the link(s) to d... Nov 29 2016, 01:36 PM
A&P Mech I picked mine up off of Amazon.
https://www.amazo... Nov 29 2016, 07:05 AM
Rob-O Mouser...just down th street from me. Nov 29 2016, 09:41 AM
Cairo94507 Scotty has a set of seat heaters for my seats. Th... Nov 29 2016, 10:29 AM
mbseto
[url=https://www... Nov 30 2016, 01:00 PM
A&P Mech Thanks! Nov 30 2016, 06:50 PM![]() ![]() |
Lo-Fi Version | Time is now: 10th March 2026 - 09:29 PM |
